It looks like every glass panel is centered on the yoke. But if you have a large (10”) with a split view , usually PFD on left and MFD on right, wouldn’t you want the PFD to be centered?
Even with 2 smaller 7” panels seem to center the panels so PFD is to the left.
Has anyone flown an aircraft, or centered their glass so PFD is centered. If so, did you like it?
I agree, but I also think your scan accommodates whatever is in front.  My PFD is slightly off center, but I don't notice it.  Same with reading the altimeter and air speed.  Weird at first, but second nature now.
ejvbtYuG1s_Rhbtm_aGFx0EHJNEthGDTi8vCNLL1Ue98uiGC_IsaTpPioUPDHValkOHwx6dfQCxAntGra3I0AURXwItTwt3DKerDFmrbUA3qozZi1RVVWp2jL6DcSLfnTIeyoVMaW4XU4vK1oWfdHxzF7FSEYgg8emHn63KKw058YgTrYf7ko7_9hpRUPevnNLTA-ZRWVO9Nl_vN4u23CcVs33BcatK7PMzsbLBCxbkbd-oDFlSGFlLkb7nF1zO96bEz7da3ZIosnLhq1EokslCvjQMgdLg2WH9GLePmFaMP1cozMiEzUEl50_AXTTcXA6QEest7t7OtVFlsfuvRtCNSSNely1OGu8SS5xWziv4WoATDiJg4ffkriIfenbPGCWVRoG_J-VauBTuBuzC2WJmqdP53gbsrJlhSK7SFZiBrBv453iRsOtOOSHwmuxluhekLBniu38HBt6764dmKUN1ZDDIcR-FYRmISXJftoUKZ3cjZxQQ7mN96WNC_iDzJ4o52IIcKi6cJjOhG1nP8u9sOamukE-Z8EdWilMq7efRGF2Pil3KAkoP7HDY3wO3_AkP-mgnr18oTnDQtSeVKUTUrvfPGIY8eug64bOnQL1lrclT6eSX59mYYL4aPFsWXWLa8lI10-oRZUcYp05fGl1lr6v-jLNcelHaL0JxhUFpm-KiZD2EQZoYMmdLpYy8LPU6oXS5QIo78SvgHpUDGJFp_qg=w1250-h937-no?authuser=0
Expand
Yes.  On the initial G500 legacy install, the PFD was centered on the control column.  The TXi - being a bit bigger - needed to go to the left a bit more to accommodate the GI275, which accompanied the autopilot.  My shop and I tried to follow the same tactic as we did with the legacy G500, but given the rear footprint of the GI275, it (and the TXi) couldn't go any further right toward the radio stack, as the tubular structure got in the way.  I've experienced no issues with the slightly off-center orientation in the latter configuration.
I assume you didn’t want to recut the panel, otherwise you could have put the 275 to the left.
The panel was indeed re-cut between those two upgrade phases.  In the airline world, the standby instrument(s) are placed to the right of the inboard DU (or PFD/MFD), so I chose to keep to that design layout to maintain a proper scan.
Is that so they can be shared by the copilot?
I don’t think the offset is noticeable after a few minutes. I’ve flown a C172 with a G3X and the offset PFD didn’t bother me at all. The original Mooney M20J 6-pack has the AI and HSI offset to the left.
Skip
If you think of where your eyes are looking, it’s either flight instruments or radio stack. I’m thinking moving the panel to the right, the backup going to the left would reduce head movements. Also would allow the panel to be higher because panel height is limited by left side where it slopes downward.
I’m putting the G5 on the right of the G3X simply because I want to reach for the G5 knobs with my right hand if I ever need the backup.
Expand
The other reason to have it on the right is that you can reset the altimeter settings with the G5 knob and it transfers to the G3X.  This is how I set and change mine and wouldn’t want to use my left hand.
Expand
On my airplane, the speedbrake button is on the left side of the yoke and I seem to inadvertently hit it with my arm whenever I reach for the left knob on my current Aspen PFD. Did that once while extricating myself from icing and the left brake didn't retract fully. :(
This discussion comes up every now and then...
Especially with the larger screens that include options for 1/3 - 2/3 layouts... vs. 50/50....
I’m pretty sure your brain will adapt to any layout you decide to use...
Your neck isn’t going to get strained by staring at the center of the panel. Or 6” to the left, or right....
Mooneys with an eight pack... have no instruments on the centerline....  proven to be a non-issue...
The centerline was reserved for vertical motion of the yoke, there wasn’t room for everything...
For design issues like this... going with the Boeing approach for layout sounds like a good proven idea...
PP thoughts only...
Expand
Playing around with panel layouts using the full size, color depictions for the G3X and G5 provided by Garmin, I noticed that if the G5 is mounted next to the G3X but with the G5 bezel top 1" below the G3X bezel top then the horizon lines on both instruments are in line which is visually pleasing.
Skip
Skip
Expand
This is how my installer did mine, flush mounted the G5 at a level where the top of the screens were at the same height and I like it.
How much extra space is required for the flush mount? I assume the backing mounting frame requires some additional room.
PP thoughts only...
I think less head movements in IMC conditions means less likely to get disoriented or airsick. It’s not about the neck.
Boeings are 2 pilot planes, so their requirements are different than mine.
Actually I did notice the off center HSI/AI when I first sat in a Mooney, my OCD kicked in but I have been able to suppress it. :-)
My G5's are way off the yoke and you don't notice it when flying....I have a few pilots who fly my plane and they never mentioned it.  You get used to it in about 1 second....it is a non issue....
Expand
Hmm I don’t think much space since it only protrudes less than an inch when not flush mounted?  I think about the back of my panel pre-glass and some of the instruments went back up to a foot and we’re stacked on too of each other.  There’s no way the G5 is anywhere near as big as my old Sandel (probably about 4x4x12). Now my back has all kinds of void space since it’s just some screens with wire bundles.
The G5 bezel is thicker than the G3X. My avionics tech recesses the G5 to match them up. Garmin doesn’t make a flush mount kit for the G5, so it’s extra labor, but it looks nicer.
Skip
Skip
Expand
We came to the same conclusion.  Here's the back of an M20J that I am working on.  We've recessed the G5's by 1/4" to match the G3x.  Note the radiorax rails (pointing wrong way here).  Had to learn how to get my CNC machine to drill the 12 holes to align with the panel holes.  Next step is to countersink and screw in place.
Having fun so far, but if you've ever wondered why some places charge '000's for new panels, there is a ton of work.
Aerodon
Looks like you need about 1/4” spacing between the G5 and G3X for the screws?
I did find them online:
