FlyingDude Posted April 11, 2021 Report Posted April 11, 2021 Hello all, Check out the tie down anchors that I sewed mainly to hold my daughter's shoulder strap. (My son still rides in child seat.) They can be used for other purposes, too. Cheers Quote
hammdo Posted April 12, 2021 Report Posted April 12, 2021 That’s nice! Could be nice for a cargo net too... -Don 1 Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 I'm thinking of a solution for the hat alcove too. I want to keep stuff without the fear that they could fly forward and decapitate us. Quote
Hank Posted April 12, 2021 Report Posted April 12, 2021 31 minutes ago, FlyingDude said: I'm thinking of a solution for the hat alcove too. I want to keep stuff without the fear that they could fly forward and decapitate us. Be careful what you put there. The weight limit is only 10 lbs after all. I keepsake headsets, tie down ropes, a blanket, fuel dip stick and sample cup, etc., back there. Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 13 minutes ago, Hank said: The weight limit is only 10 lbs after all. Wasn't it 20 lbs (which is almost 10 kg)???? 13 minutes ago, Hank said: headsets, tie down ropes, a blanket, fuel dip stick and sample cup, etc I want to keep exactly these kinds of things plus first aid kit and maybe 1-2 oil bottles but in case of some mild windshear that makes you lose only 10-15 kts, a headset can hurt a lot. In case of an accident, it can be lethal. You know, hopefully it never happens to anyone but have you watched the movie pentalogy "Final Destination"? Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 17 minutes ago, Hank said: weight limit is only 10 lbs after all. I have 3 copies of the poh and they're all in the plane. I'll check mine tomorrow Quote
Hank Posted April 12, 2021 Report Posted April 12, 2021 17 minutes ago, FlyingDude said: I have 3 copies of the poh and they're all in the plane. I'll check mine tomorrow You need a PDF. Here's mine: Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 Ouch. 10lbs ain't nothin' I found the pdf copy of the poh for the chaparral, not the super 21 which is what I have... oh well. In that case I won't bother design anything for the hatrack... Not worth it Quote
Hank Posted April 12, 2021 Report Posted April 12, 2021 11 minutes ago, FlyingDude said: Ouch. 10lbs ain't nothin' I found the pdf copy of the poh for the chaparral, not the super 21 which is what I have... oh well. In that case I won't bother design anything for the hatrack... Not worth it Check the Downloads section here. I got the last year's copy for my C there (1977). See what is available for Es. 1 Quote
Guest Posted April 12, 2021 Report Posted April 12, 2021 Now that you’ve got the seat belts anchored, it’s time for a modern ELT. Clarence Quote
Tcraft938 Posted April 12, 2021 Report Posted April 12, 2021 Hat rack is where I put my cabin cover, cowl plus, pitot cover bungee cords to lock control surfaces and tiedown straps. Weight is 10.4 lbs and the .4 has not bothered anything in 120 hours of flying. Even though I hangar, never know when have to land somewhere and spend the night, etc. Also all of it is pretty soft so not too worried about being hit by it, and if done properly the cabin cover packs tight. I considered purchasing a M20C that had a 15 gallon aux tank in the baggage compartment. That made the compartment virtually useless for baggage, and as a result the owner had a bunch of stuff on top of the tank and in the hat rack. VERY easy for that stuff to migrate forward over the backseat, not to mention, way more than 120 lbs back there. Maybe that explains why he reported it was faster than most Cs? :-) Quote
Hank Posted April 12, 2021 Report Posted April 12, 2021 When I travel, I throw the canopy cover on top of all the baggage. Helps keep it in place, and is handy if I tie it down. Otherwise, the canopy cover lives on a shelf in the hangar. Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 5 hours ago, M20Doc said: modern ELT I have a handheld one Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 4 hours ago, Tcraft938 said: Maybe that explains why he reported it was faster than most Cs? I hope he never emulates the Fine Air 101 flight Quote
A64Pilot Posted April 12, 2021 Report Posted April 12, 2021 (edited) There are inexpensive elastic nets used on motorcycles to secure stuff to the seat, they are made from bungee cord. ‘One of those would work well to secure stuff on the hat rack if you wanted, only light stuff of course Seems even harbor freight has one https://www.harborfreight.com/12-in-x-15-in-motorcycle-cargo-net-69621.html?cid=paid_google|||69621&utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&gclid=Cj0KCQjw38-DBhDpARIsADJ3kjmkXYxRG6AUY_qUdRzoREzYzw5iNHZTzVkojtpwqxMGOQ4hql8ETB8aArCcEALw_wcB Edited April 12, 2021 by A64Pilot 1 Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 27 minutes ago, A64Pilot said: inexpensive elastic nets Awesome. Thank you. I'll get some. I need to figure out how to fasten them to the fuselage. The screws I spotted are trim screws, holding the plastic. I'm not sure if they're sturdy enough. Big again... I may be overthinking it for 10 lbs. Lol Quote
gsxrpilot Posted April 12, 2021 Report Posted April 12, 2021 This is an interesting conversation. I just took my cargo straps out of the plane. In my M20K, there are two straps, four pieces, that are bolted to the floor of the baggage compartment. I didn't get them unbolted while the belly was off, so I just cut the straps and tucked the ends back under the carpet. I'd never once used the straps and It cleaned up the look of the baggage area 1 Quote
FlyingDude Posted April 12, 2021 Author Report Posted April 12, 2021 48 minutes ago, gsxrpilot said: just took my cargo straps out of the plane. Were they stock or installed by a previous owner? Quote
larryb Posted April 13, 2021 Report Posted April 13, 2021 Here is my solution. This is with rear seats removed. 3 Quote
gsxrpilot Posted April 13, 2021 Report Posted April 13, 2021 1 hour ago, FlyingDude said: Were they stock or installed by a previous owner? They were original equipment installed at the factory. 1 Quote
