robert7467 Posted September 22, 2020 Report Posted September 22, 2020 Anyone know what would cause this when I try selecting GPS? ILS lockout is disabled. I cant seem to get the deviation bar/gps selection to stick. However, I can get the GPS bearing pointer. Sandel 3308 KX 165 Garmin 420 GPS 20200921_150918 (1).mp4
carusoam Posted September 23, 2020 Report Posted September 23, 2020 What GPS do you have supplying the data? It may be a GPS setting that needs to be selected... or data to be delivered to the display... for something like a G530W... it has a VOR receiver, an ILS, And vertical guidance via GPS... three separate receivers in a box... If it isn’t a WAAS GPS, it doesn’t have vertical guidance to deliver... Best regards, -a-
robert7467 Posted September 23, 2020 Author Report Posted September 23, 2020 It's a 420, like a 430 without the nav. I am sure its just a setting somewhere.
mike_elliott Posted September 23, 2020 Report Posted September 23, 2020 Have you recently added the GPS and does it have WAAS? If so, your Sandel may need a firmware upgrade to support WAAS 1
robert7467 Posted September 23, 2020 Author Report Posted September 23, 2020 No wass.. This is a new install that I am trying to work out all the gremlins on.
carusoam Posted February 20, 2021 Report Posted February 20, 2021 Message for @robert7467 above... -a-
Gary0747 Posted February 21, 2021 Report Posted February 21, 2021 To get the deviation bar to show on th Sandel sn3308 you have to have the map settings turned off.
