previous owner had an A&P install a skytek starter.  he didnt update the W&B, just said empty weight decreased by 9.7lbs.  i want to redo the w&b and give it to my a&p to look at and sign for me.  plane is 300 miles away at the moment, and i dont have access to the equipment list.  could anyone share theirs?  looking for the page with the starter, and if the strobe boxes are on the equipment list.  all three (both wings and tail) thanks in advance!
Bryan
PS: plane is a 1990 J
There is plenty of of discussion around here regarding WnB updates... mistakes that go as far back as the factory...
And very little standardization going back that far...
The usual next step includes re-weighing... which may work out well...
ive read a few.  closest i can find for the starter is -18".
ill reweigh after paint and interior down the road....
You can redo it starting from the factory number and including all changes.  I did that one year at annual.  The IA went over it line by line to make sure all changes were there and the numbers were right and then signed it.  Its the new baseline now and correct.
Some stations are provided in the type certificate.  Two starter options are given on the J at -23 inches.  If you took off one of those and the skytec went in the same place, that should give the info needed to do the W&B.
https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/6ea0f05ecca8304486258305006833cf/$FILE/2A3_Rev_58.pdf
ill read through that... thank you
