Ross Taylor Posted July 7, 2020 Report Posted July 7, 2020 And...yes...before someone states the obvious, it's named a rectangle. HAHA! The Miniflo shares what seems to be a somewhat common shape for the cutout, a rectangle with angled corners. I got a diagram from Shadin and could cut it manually and carefully, but this seems to be a commonly used shape and I'm hoping to find a punch or trim ring for it (in case the cutting isn't as perfect as we'd like). So far, I can't find either of those...but I'm sure I'm challenged by not knowing the name for this shape...if there is a standard name for the panel opening. Thanks MS! Ross Quote
PTK Posted July 7, 2020 Report Posted July 7, 2020 6 minutes ago, Ross Taylor said: I'm sure I'm challenged by not knowing the name for this shape...if there is a standard name for the panel opening. That's called 1/2 ATI instrument cutout. 2 1 Quote
Ross Taylor Posted July 7, 2020 Author Report Posted July 7, 2020 1 hour ago, PTK said: That's called 1/2 ATI instrument cutout. Why, thank you very much! Quote
StevenL757 Posted July 7, 2020 Report Posted July 7, 2020 A Shadin Miniflo 1/2 ATI Octagonal Instrument Panel Cutout Abbreviated SMAOIPC. ;-) 1 Quote
PTK Posted July 7, 2020 Report Posted July 7, 2020 8 minutes ago, Ross Taylor said: Why, thank you very much! Don’t mention it! 1 Quote
Lance Link Posted July 8, 2020 Report Posted July 8, 2020 That would be easy to make out of plastic. Quote
Aerodon Posted July 12, 2020 Report Posted July 12, 2020 Ross, I have that template for my CNC machine, what do you want the outside line to look like and what thickness material? I'll cut and mail it for $25, you can trim if necessary and paint. Don supercub180@gmail.com 1 Quote
Ross Taylor Posted July 12, 2020 Author Report Posted July 12, 2020 30 minutes ago, Aerodon said: Ross, I have that template for my CNC machine, what do you want the outside line to look like and what thickness material? I'll cut and mail it for $25, you can trim if necessary and paint. Don supercub180@gmail.com Wow, right on! Thanks - I’ll email you tomorrow. Quote
Missile=Awesome Posted July 14, 2020 Report Posted July 14, 2020 On 7/11/2020 at 11:06 PM, Aerodon said: Ross, I have that template for my CNC machine, what do you want the outside line to look like and what thickness material? I'll cut and mail it for $25, you can trim if necessary and paint. Don supercub180@gmail.com Cut Two. I need one too. I’ll send a PM so you can give me mailing address for check. Thank you! 1 Quote
