TheAv8r Posted September 17, 2019 Report Posted September 17, 2019 We purchased the Donaldson spin on oil filter P/N 77852 for Lycoming engines to be able to make oil changes easier ('65 M20E) . My question is the part doesn't come with installation instructions... I had a spin-on filter STC on my Cessna back in the day and I know it specifically specified desoldering the oil screen and removing it when installing the spin on kit, is it the same with the Mooney kit or is it installed over the screen?
7.Mooney.Driver.0 Posted September 17, 2019 Report Posted September 17, 2019 http://www.grummanpilotsassociation.com/wp-content/uploads/2015/01/SSP-885-1-Lyc-Oil-Filter-Installation-Manual.pdfHope this helps. Sent from my iPhone using Tapatalk 1
TheAv8r Posted September 18, 2019 Author Report Posted September 18, 2019 Thanks siu. This is perfect. Looks like we'll need to grab some extra parts! 1
7.Mooney.Driver.0 Posted September 18, 2019 Report Posted September 18, 2019 Thanks siu. This is perfect. Looks like we'll need to grab some extra parts! You welcome.. I don’t know what happen to what i wrote before the link but any how. When i installed the spin on adapter on my mooney i removed the screen housing and screen, removed the temperature probe and the thermostatic valve. Installed the temp probe and thermostat valve on the housing, removed the old gasket installed new gasket for the adapter assembly..... Advice your A&P about being careful with the LH lower stud i’ve seen a few guys strip those when installing the oil filter housing adapter.. Good luck with everything..Sent from my iPhone using Tapatalk
cruiserflyer Posted November 5 Report Posted November 5 On 9/17/2019 at 1:27 PM, 7.Mooney.Driver.0 said: http://www.grummanpilotsassociation.com/wp-content/uploads/2015/01/SSP-885-1-Lyc-Oil-Filter-Installation-Manual.pdf Hope this helps. Sent from my iPhone using Tapatalk Can you refresh this link? I know it's been years :-D
47U Posted November 5 Report Posted November 5 1 hour ago, cruiserflyer said: Can you refresh this link? I know it's been years :-D Here’s the document, but not sure if the dialogue on the Grumman site was relevant. https://www.lycoming.com/sites/default/files/file/2025-01/SSP-885-2.pdf
