Dear Folks, I want to buy Nomex CWU 27/P Flight Suit in person. I live in Chicago. Is there any pilot shop that sells this flight suit in person? Preferably some place near Chicago. Worst case, some place near Oshkosh WI, as I'll be there for Air Venture 2019.
I want to buy the following:
  1. Nomex CWU 27/P Flight Suit
  2. Anti-G pants CSU-13B/P
  3. USAF MBU-20/P oxygen mask
  4. HGU-55/P helmet
  5. Bates Leather Flight
Edited by Saul Goodman
1 hour ago, carusoam said:
A local racetrack ‘pro-shop’ may be a resource?
finding one with Mooney artwork will be interesting.
Flight suits and race suits are very different.   I know this partly because once in a while somebody tries to (or at least asks about) using a nomex flight suit for a race.  They don't meet the requirements, and race suits generally aren't very comfortable when worn for long periods (e.g., they're kinda hot).  They also don't have very many pockets, which most flight suits do.   You don't write a lot of stuff down or dig out a chart during a race.  ;)
  4. HGU-55/P helmet
Just curious why you want all of that?
brian
Gibson & Barns!! Order a few sizes and return what doesn’t fit.
The helmets are on the small size order up.
There are a few different mask sizes too. You’ll need a crew60 for most O2 applications too.
The HG55 is an old school helmet. I can’t stand the visor operation. HG68 is a little better.
watch the impeadance of the mics if your working with GA radios. It’s a pain in the butt.
Have fun with whatever project you are working!!
-Matt
+1 for Gibson & Barnes http://www.gibson-barnes.com They bought out Flight Suits LTD, and is where my company goes for our equipment. Their flight suits are true to size in my experience.
The g-suit may be a little more difficult to come by. I'll ask at work.
There is a considerable fitting process for the gear you're talking about that requires a level of expertise and experience. I would assume you were already working with someone with that training, but then again they would be able to tell you where to get the equipment so I won't assume.
Good luck!
Cheers,
Rick
Eric,
1) Expecting flight and driving suits to be different.... to some extent...
2) What I was wondering, or possibly expecting, is... are flight suits and driving suits made by the same companies..?
3) If Company A builds both driving suits and flight suits...
In this odd possibility... the OP can try on a driving suit built by Company A for fit... and then, almost comfortably, buy the same size for a Company A flight suit....
4) The Central Jersey Dragstrip has a proshop with these things for sale... helmets, gloves, shoes, balaclavas, suits etc...
5) The only time I’ve seen a flight suit... was on a pilot doing aerobatics or after the flight.... not in stores...
6) The buying process sounds as expensive as the suit... an amu here, an amu there...
7) not getting the right size up front... another amu...
8) I was picturing Sean D Tucker.... not sure, what he carries in those pockets.... :)
9) Backing up a few steps...
Saul, Is the flight suit an everyday Mooney flying type of flight suit? Or something completely different?
10) Improving seat belts is also a possibility in the scheme of safety during and after the HARD landing...
3 hours ago, carusoam said:
Eric,
The main race suit suppliers in the US are names like Sparco, OMP, and Alpinestars.   I checked all three and none seem to have any flight suit offerings.   Doing a web search on "Nomex CWU 27/P flight suit"  brings up several options, and one supplier is apparently a company called "Propper" that is a "tactical supply" vendor.   Coincidentally, they're having a closeout on CWU 27/P Nomex flight suits for $49.99 if you get one in sage.
Race suits are made to be compliant with a few different specs, particularly SFI (in the US) and FIA (internationally).  Most sanctioning organizations have rule sets that indicate the minimum SFI or FIA suit spec for a particular class or application.   e.g., road racing suits may be a different minimum spec than drag suits, etc.  Drag rules often allow two-piece suits while road racing seldom does.   Sometimes the different specs just give tradeoffs on construction, e.g., multi-layer suits used to be the norm but these days the more expensive suits are sometimes single layer and therefore lighter and not as hot to wear.   Race suits also usually require closed-cuff ankles and sleeves, a collar that can close around a balaclava, and some have strong epaulets so that the safety guys can drag your butt away from the car that you just crashed.   I think most flight suits don't have any of that stuff.
Flight suits don't seem to be covered by too many specs, and I can't seem to find what "CWU 27/P" even means; maybe it's just a particular style.   There is a MIL-C-83141A spec that some CWU 27/P suits are made to.
Since Nomex is just a family of material types, anybody can make something out of Nomex and call it a Nomex suit.
Good race suits these days are in the $800-$2k range, although you can get a decent, SFI-compliant suit for $300.   Looks like the flight suits, even the mil-spec ones, run from $50-$200 or so.
My understanding of the way that nomex works is that the fibers in the weave swell and close together to form a solid barrier when exposed to heat.   In doing so they lose a lot of other properties, like the ability to breath, etc.   They're one-time use only.   In racing if the suit has been exposed to high heat it's done...a lot of safety gear is one-time use;  harness, helmet, suit, seat, etc...
It is interesting to compare the differences.   Looks like flight suits are a lot cheaper in general, but I'd expect that.
Edited by EricJ
OP is going to look like a boob getting out of him Mooney with all that on. Might as well get some epaulettes to go with it.
If I had my choice of anything to wear in the Mooney I think it’d be Armani.
Come on now... what if "Danger Zone" was also playing loudly in the background?:lol:
Edited by David_H
I'd still want Armani.  Goes with anything.  They say clothes make the man.  Don't like to think about what my rags are making me.
Hey Saul,
not sure if it helps, there is a large Army/Navy surplus store on the fox river in  south Elgin. maybe worth a ride to see what they have or can access for you. I second Gibson and Barnes. I have a few Nomex suits over the years, not sure what level of protection but better than nothing for the situation I was in at the time. I have had one tailored years back as I had a 50 inch chest and a 36 waist so I needed to have the middle adjusted so I wasn't moving around in a large green bag. The last one I bought is a size 48 long and with the Velcro hip adjustments it fits great.
The helmet, check out evil bay, the G suit seems hard to come by. Best of luck
Not sure if any of these guys are wearing Armani.
But it is “proof” you can put 4 adult, well-dressed gentlemen in a short-body Mooney!
It's proof you can take a pic that gives that impression.  ;)
That’s back when the average ‘murican wasn’t morbidly obese like myself...
@Saul Goodman
You can try here: https://lifesupportintl.com/collections/clothing/products/clo-1450-00 You will pay dearly, but they can help you.
If you don't mind used gear, try here: https://www.flighthelmet.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=PRGS
I'm curious as to what you're going to need the gear for too.
Cheers,
Rick
Talk to your local aeromedical service- they probably have tons of gross and well worn nomex suits.
Dont' forget gloves.
What gives ... an L39...?
That guy that used a DER to install a second alternator circuit in a J model wore a flight suit.
I'm not sure how much it would actually help in an in cabin fire....
I prefer shorts in the summer.
  • 2 weeks later...
  • Members Online
