Yetti Posted February 23, 2019 Report Posted February 23, 2019 The adventure begins. A programming note to start this one off. To get the fuel servo off, you have to remove the starter, to get to the last bolt on the starter, you have to remove the alternator and the bracket. When I told the Servo repair shop that we found an orange O ring in it, he said that was from the 70s - 80s. I would guess it has never been touched. Full day project to remove with fuel divider and fuel nozzles. And I am sore. Much props to those A&Ps that do this day in and day out. 8 1 Quote
RLCarter Posted February 23, 2019 Report Posted February 23, 2019 2 hours ago, Yetti said: Much props to those A&Ps that do this day in and day out. If it was easy everyone would be doing it..... 2 1 Quote
Yetti Posted February 23, 2019 Author Report Posted February 23, 2019 8 hours ago, RLCarter said: If it was easy everyone would be doing it..... It's an honest living that is for sure. 1 1 Quote
M20F Posted February 23, 2019 Report Posted February 23, 2019 12 hours ago, Yetti said: A programming note to start this one off. To get the fuel servo off, you have to remove the starter, to get to the last bolt on the starter, you have to remove the alternator and the bracket. But wait I just read another thread here about how easy Mooney’s are to work on! 1 1 Quote
ArtVandelay Posted February 23, 2019 Report Posted February 23, 2019 Every time I work on my plane, it takes twice as long as planned.But very satisfying when job is completed.Tom 2 Quote
Yetti Posted February 25, 2019 Author Report Posted February 25, 2019 (edited) On 2/23/2019 at 7:32 AM, M20F said: But wait I just read another thread here about how easy Mooney’s are to work on! There is nothing hard about what was done Friday. I think you could take the whole plane apart with a 3/8, 7/16 and 1/2 inch wrench and a #2 Philips. I would not consider Mooneys maintenance hogs, but I have never owned any other type plane. I spend more time working on the mower deck for the tractor than I do the plane. Not that you should ever add things up for planes but since everyone wants to know Running totals 1 day spent removing the Fuel Servo half day spent ordering stuff Aircraft Spruce $250 - consumables New duct boot - $300 New number 1 fuel line $60 Fuel servo rebuild, fuel divider rebuild, ???? Vertical card compass $175 Debating on the 406 ELT $500 Edited February 25, 2019 by Yetti 1 Quote
Yetti Posted March 2, 2019 Author Report Posted March 2, 2019 Report back from the Carb shop. Lots of old parts in the fuel servo. 2-3 fuel nozzles are bad. New mooney induction boot $300 New number 1 fuel line $50. Was cross threaded. 406 ELT $500 Day 2-3 Lubed Gear Installed 406 ELT which involved cleaning filiform corrosion around antenna. Washed the lower cowl since it was off. Made up new ground wire for alternator Cleaned and Installed plates on the new boot. Tool of the day is leather punch. Lots of panels Waiting for Fuel Servo 1 Quote
Yetti Posted March 2, 2019 Author Report Posted March 2, 2019 http://www.kellyaerospace.com/articles/FuelInjection.pdf Quote
GDGR Posted March 2, 2019 Report Posted March 2, 2019 My overhauled servo was around 1200 Canadian. Quote
Yetti Posted March 21, 2019 Author Report Posted March 21, 2019 had to drop in a Texas drawl to get a good update on the Fuel Servo. A couple of yes Please and Yes mams. should be back in a couple of days. 1 Quote
Yetti Posted March 28, 2019 Author Report Posted March 28, 2019 (edited) And I was able to pay 2.2 AMU bail to get out of the Fuel Servo Prison. A good day of work and the plane is back together. Found that the last certified person (before I owned the plane) installed the alternator bracket upside down. No spacing needed when the bracket is on proper. Couple more days to make sure things are ship shape shape and it will be back in the air. I am going to be sore tomorrow. Edited March 28, 2019 by Yetti 1 Quote
carusoam Posted March 28, 2019 Report Posted March 28, 2019 Great updates, Yetti! Best regards, -a- Quote
Yetti Posted March 28, 2019 Author Report Posted March 28, 2019 (edited) With some estimates. Looks like this is where we will be cost wise. Aircraft Spruce 800 Carburetors of Texas 2200 Prop hub AD 200 Annual inspection 600 5-7 days of my time Edited March 28, 2019 by Yetti Quote
KLRDMD Posted April 1, 2019 Report Posted April 1, 2019 On 3/28/2019 at 5:21 AM, Yetti said: With some estimates. Looks like this is where we will be cost wise. 5-7 days of my time THAT's the expensive part !!! Quote
Hank Posted April 1, 2019 Report Posted April 1, 2019 On 3/28/2019 at 7:21 AM, Yetti said: With some estimates. Looks like this is where we will be cost wise. Aircraft Spruce 800 Carburetors of Texas 2200 Prop hub AD 200 Annual inspection 600 5-7 days of my time What carburetor work is your F getting????? Quote
Yetti Posted April 1, 2019 Author Report Posted April 1, 2019 That's what the shop is called. Does servos too Quote
Jim Peace Posted April 3, 2019 Report Posted April 3, 2019 Just went through a 4800 annual on a 64c at a great MSC big items were: New oil cooler replace a ring gear that was rubbing slightly on the sky tech starter, that was installed by a MSC up north that way....cost me a ton to fix. bunch of other little stuff that just seems to add up... Next year should be just the annual,,,yeah right,,,,and a transponder pitot static check.... Quote
Yetti Posted April 5, 2019 Author Report Posted April 5, 2019 And compressions are 79 across the board. Retimed the right mag a bit. Got the prop hub feeled up. Grumpy IA "all you pilots say there is nothing wrong with the plane" I said "Nope not me. Find me something to fix." Waiting on paperwork. 1 Quote
Yetti Posted April 19, 2019 Author Report Posted April 19, 2019 The adventure ends with signed off paperwork Aircraft Spruce 800 $500 for a new 406 ELT - Bought some packages of bolts and cotter pins. Needed 4 cotter pins. 2 for the fuel servo and 2 for the alternator and some for the wheel bearings. so I bought the $40 variety pack. Carburetors of Texas 2200 Prop hub AD 200 Annual inspection 600 New induction Boot from Money 300 New cost per hour for this year 310 an hour.... But it looks like we got 25 years out of the servo so maybe 2200/25 years.... 1 1 Quote
Yetti Posted April 19, 2019 Author Report Posted April 19, 2019 Epilogue With the OH fuel servo and 2 new nozzles, the engine seems to be running much much smoother. I asked the IA if this was possible. He said maybe. 1 Quote
steingar Posted April 19, 2019 Report Posted April 19, 2019 I used to do the annuals on my Cherokee, but they only took a day. I think it takes a day just to get all the covers off the $%#&##@!!! Mooney, and I swear about half them don't fit back on. I'd love to stick around and help with the annual, but my mechanic certainly doesn't want it, and I do have this job thing. I'll never know how it is that this elf you who do this are able to get that kind of time off work. If I did it I'd have no time left to fly the damn airplane. Quote
Hank Posted April 19, 2019 Report Posted April 19, 2019 3 hours ago, steingar said: I used to do the annuals on my Cherokee, but they only took a day. I think it takes a day just to get all the covers off the $%#&##@!!! Mooney, and I swear about half them don't fit back on. I'd love to stick around and help with the annual, but my mechanic certainly doesn't want it, and I do have this job thing. I'll never know how it is that this elf you who do this are able to get that kind of time off work. If I did it I'd have no time left to fly the damn airplane. In my hangar, I prepped in advance by removing cowl, spinner, inspection plates, dog house, etc., so it's ready for the IA when he arrived. Then we worked together. I buy lunch, we both go home for supper. Usually done in a 3-day weekend, then I'd put her back together. Before I moved, the IA would take it to the Maint. Hangar, pull plugs and check compression. I'd stop by after work, remove the rest of the panels; clean, gap and test plugs; grease the landing gear; etc. I'd leave a note with what I did, sometimes he'd be there on Saturday while I was working; sometimes I'd call him during the day when I had a break at work. Usually took 2-3 weeks. Every year I did a little more as we developed a relationship and trust. This year, my IA retired and stopped answering his phone and email, leaving me up the proverbial creek without propulsion. So I called the only other one I knew, and he was willing to do it and could start before the old one expired, meaning I could fly it to him (15 min, wheels up to wheels down). This guy also doesn't respond much to phone calls, texts or emails; doesn't follow instructions; did things I explicitly asked him not to do; induced failures in things he wasn't supposed to work on; and presented the highest bill for any work ever done on my plane during 12 years of ownership. Took 70 days, then 13 more to finish writing the invoice. Oh, and he no longer has the initial quote where we discussed and I marked which tasks to do and which not to do, although the invoice is (hand) written on the exact same form, all 11 pages of it . . . . Did I mention the logbooks are signed off on 29 March, and he called me on 5 April to tell me it was ready? <-- This doesn't even come close . . . Now I need another drink! 1 4 Quote
David_H Posted April 19, 2019 Report Posted April 19, 2019 5 minutes ago, Hank said: This year, my IA retired and stopped answering his phone and email, leaving me up the proverbial creek without propulsion. So I called the only other one I knew, and he was willing to do it and could start before the old one expired, meaning I could fly it to him (15 min, wheels up to wheels down). This guy also doesn't respond much to phone calls, texts or emails; doesn't follow instructions; did things I explicitly asked him not to do; induced failures in things he wasn't supposed to work on; and presented the highest bill for any work ever done on my plane during 12 years of ownership. Took 70 days, then 13 more to finish writing the invoice. Oh, and he no longer has the initial quote where we discussed and I marked which tasks to do and which not to do, although the invoice is (hand) written on the exact same form, all 11 pages of it . . . . Did I mention the logbooks are signed off on 29 March, and he called me on 5 April to tell me it was ready? This sort of story is becoming very common. How do these shops stay in business? Quote
Prior owner Posted April 19, 2019 Report Posted April 19, 2019 There is a shortage of shops everywhere...especially avionics shops. People line up for the kind of experience you just had. It’s crazy. 1 Quote
