The airspeed indicator in my C is like all others, outer ring in mph, inner ring in kts.   I think in kts and would really prefer it the other way around.
Does anyone know of a place that either can produce/silkscreen such a thing?  Of course I'd like the Mooney logo on the dial.;)
I searched before writing this post, and I saw that @Marauder sold one for an F model back in May.   Something like that is what I want.  See photo here.
The problem stems from the fact that every other a/c I've ever flown has shown kts in the outer ring.   Because 80 mph < 80 kts, it causes a distraction at a busy times that I could just avoid if the first outer number I saw was kts, and I didn't have to focus under the pointer.
Any ideas?
The airspeed indicator in my C is like all others, outer ring in mph, inner ring in kts.   I think in kts and would really prefer it the other way around. Does anyone know of a place that either can produce/silkscreen such a thing?  Of course I'd like the Mooney logo on the dial.
I searched before writing this post, and I saw that [mention=9886]Marauder[/mention] sold one for an F model back in May.   Something like that is what I want.  See photo here.
The problem stems from the fact that every other a/c I've ever flown has shown kts in the outer ring.   Because 80 mph Any ideas?
If your POH shows both MPH and knots (as mine did), you can do what I did with my airspeed indicator; flip the knots and MPH location on the ASI. Mid-continent did my conversion and overhauled the unit for around $350. If your POH only shows MPH, you can still do the flip, but not remove the MPH
I was like you, it was driving me nuts to go back and forth between the units.
I should add, that if your POH is in both units, then you can remove the MPH if you go with something that displays only in one unit, like my Aspen.
2 hours ago, Fred_2O said:
I don't think in terms of V/C.  Just V (kts).;)
Welcome to Vintage (certified) planes! Please learn to think in mph, as shown on your Instruments and in your Owner's Manual.
That. Is your car reading in kilometers/hour? Your V speeds are all in mph. You should fly it that way. If you really need your cruise speed in knots your phone can figure it out for you. Such a change in the airspeed indicator is a pure waste of money.
My ASI has mph on the outside, and rarely-used knots on the inside. All V-speeds and Performance Tables are in mph.
But my G430W shows groundspeed in knots.
ATC has never asked or assigned me a speed, I just learned to fly approaches at 105 mph instead of 90 knots. No biggie . . . . .
Since my POH is all in mph I rather stick with that. Initially it bothered me, but now when a C or P driver asks me what she cruses at I say 165.......:)
I’ve yet to see a GPS that can’t be reset for whatever units you want.  Heck, my motorcycle will do that. Km/hr, though not knots.
Never bothered to look, it doesn't bother me at all and from what I can tell, it also doesn't matter.
Just focus on the inner ring and you will get comfortable with it over time.   I think of all of my relevant speeds in terms of knots in order to be consistent with the rest of the aviation community; if ATC gives you a speed they will do so in knots. Just be consistent and not jump back and fourth.  BTW, the thing that I really miss on my M20C airspeed indicator is the TAS window (even if in MPH) since it is a quick way to monitor TAS. Unfortunately, mine doesn't have one so I have to use an app on my phone.
Nice equipment Marauder!
