My 66 M20F gear switch does operate, but the knob is loose and even when switched it is very sloppy..I did try to tighten the knob and just think its time for a new one .Does anyone know where to buy a replacement? Does someone make new ones? Thanks
20 minutes ago, Mooneycrazy said:
Ok, thanks for that information......Any advice as to where to find one...?
Google is your friend, enter the part number and Micro switch.  You’ll find many.
I was unable to find a switch like the factory one... Are you thinking it would have to be replaced with an aftermarket switch simluar...not sure I understand....I was thinking of a full replacement part from an aircraft parts supplier....After seeing all the Mooneys Ive seen...so many of the older ones looked in simluar condition.....I would think someone would have needed to replace theirs as well...?
