xcrmckenna Posted August 10, 2017 Author Report Posted August 10, 2017 I've got two. and a hawk on a cable. Sent from my iPhone using Tapatalk Quote
xcrmckenna Posted August 19, 2017 Author Report Posted August 19, 2017 Just make one. It turned out better than I thought it would....Sent from my iPhone using Tapatalk 1 Quote
LANCECASPER Posted August 19, 2017 Report Posted August 19, 2017 Now please paint the screw heads black 1 Quote
xcrmckenna Posted August 19, 2017 Author Report Posted August 19, 2017 Now please paint the screw heads black I have two broken shock mounts. They should be here Monday or Tuesday. I think I'm going to replace as much hardware in the panel as I can with ss. Sent from my iPhone using Tapatalk Quote
gsxrpilot Posted August 19, 2017 Report Posted August 19, 2017 Wouldn't brass be better in the panel? Quote
MIm20c Posted August 19, 2017 Report Posted August 19, 2017 14 hours ago, xcrmckenna said: Not sure what this is? Quote
xcrmckenna Posted August 19, 2017 Author Report Posted August 19, 2017 Wouldn't brass be better in the panel? It would, but doubt I can find enough brass hardware here to replace everything. The screws and nut are already steel so I won't be making it worse magnetic wise. Sent from my iPhone using Tapatalk Quote
xcrmckenna Posted August 19, 2017 Author Report Posted August 19, 2017 Not sure what this is? That is the back side of the panel stack. With the new encoder mounted to it. Sent from my iPhone using Tapatalk Quote
carusoam Posted August 30, 2017 Report Posted August 30, 2017 The tough part of buying a pristine plane... Every addition has to keep up with the pristine-ness that is already there. Nice work xcr, -a- 1 Quote
xcrmckenna Posted August 30, 2017 Author Report Posted August 30, 2017 The tough part of buying a pristine plane... Every addition has to keep up with the pristine-ness that is already there. Nice work xcr, -a- Thank you. I was surprised how good the cover came out with my metal working skills when I don't get to use a welder...Sent from my iPhone using Tapatalk 1 Quote
