We are having an blowout on new overstock Aspen ATX100 and ATX100G 978 MHz ADS-B Transceivers! The Aspen ATX100 series is the perfect ADS-B In/Out solution for aircraft owners who fly below 18k feet and have both Aspen Evolution PFDs/MFDs and Garmin GNS avionics.
UPDATE: Sold out.
For WAAS GNS owners: The ATX100 transceiver provides an ADS-B In/Out solution for aircraft equipped with a Mode A/C or Mode S transponder and a WAAS 430W/530W. The ATX100 can depict ADS-B In weather and traffic on Aspen Evolution PFDs/MFDs and traffic on GNS series. This approved interface allows you to use the existing GPS position from the 430W/500W and eliminates the need to install a costly GPS antenna saving you time and money. A UAT antenna is required.
For non-WAAS GNS owners: The ATX100G provides an ADS-B In/Out solution for aircraft equipped with a Mode A/C or Mode S transponder without a compatible WAAS GPS navigation receiver. The ATX100G transceiver has an internal WAAS GPS sensor and depicts ADS-B In weather and traffic on Aspen Evolution PFDs/MFDs and traffic on GNS series. Requires a $290 WAAS antenna (not included).
Edited by Avionics Source
Chase, I'm not exactly in the market for this right now, but am leaning towards an Aspen. I currently have a 330ES so I'm compliant with the OUT requirements already. Can this box be configured for IN only? I would want traffic/wx on an Aspen if/when I go for one.
Sent from my LG-US996 using Tapatalk
Yes this box can do exactly that. In fact, I just sold an ATX100 to a BeechTalk customer who will be pairing this with their Evolution 2000 with a $0 ADS-B unlock. There's no cheaper way to get "in" presently. Just turn off all the "out" functionality and the installation is even more simplified.
