blurceo Posted June 16, 2017 Report Posted June 16, 2017 Does anyone know if the laser gear set is all you need for rigging the gear on the 20C? It has one tool for the nose and one for the mains. My mechanic seems to think that I need two main gear tools to rig the gear. Can anyone shed some light one this? Quote
mike_elliott Posted June 16, 2017 Report Posted June 16, 2017 Just now, blurceo said: Does anyone know if the laser gear set is all you need for rigging the gear on the 20C? It has one tool for the nose and one for the mains. My mechanic seems to think that I need two main gear tools to rig the gear. Can anyone shed some light one this? I am not sure I would let your mechanic rig the gear if this is his understanding. @sabermech can fix you up with the right gear tools. 4 Quote
blurceo Posted June 16, 2017 Author Report Posted June 16, 2017 Just now, mike_elliott said: I am not sure I would let your mechanic rig the gear if this is his understanding. @sabermech can fix you up with the right gear tools. Yeah, that is what I was thinking. I thought I misunderstood him the first time he said it. But i asked again and he said the same thing. Thanks! Quote
RLCarter Posted June 16, 2017 Report Posted June 16, 2017 1 main rigging tool and 1 nose rigging tool is all that is needed, assuming you have a dial type torque wrench (0~300 in lb) Quote
Guest Posted June 18, 2017 Report Posted June 18, 2017 Tell him the main gear rigging tool is flipped around for the opposite gear. Â You may want to do some reading of the manual with him before doing any adjusting to your gear. Clarence Quote
Bob_Belville Posted June 18, 2017 Report Posted June 18, 2017 On ‎6‎/‎16‎/‎2017 at 10:36 AM, mike_elliott said: I am not sure I would let your mechanic rig the gear if this is his understanding. @sabermech can fix you up with the right gear tools. aka @Sabremech 1 Quote
N201MKTurbo Posted June 18, 2017 Report Posted June 18, 2017 Are you having a problem with your gear? If not I wouldn't adjust anything. I still contend the preload tools are just a quick and easy check of the rigging not the tools to use to adjust to a particular value. If you adjust the spring bungees so both nose bungees and and both main bungees work in unison and they all go to just short of full compression through the extension stroke. The preloads will measure within range. 1 Quote
Sabremech Posted June 18, 2017 Report Posted June 18, 2017 I have plenty of gear tools in stock. As others have said here, you only need one main and one nose tool for checking rigging. David Quote
philipneeper Posted July 30, 2017 Report Posted July 30, 2017 Whats your $ for the tools? Â @Sabremech Quote
Guest Posted July 30, 2017 Report Posted July 30, 2017 8 hours ago, philipneeper said: Whats your $ for the tools? Â @Sabremech Priceless, if you don't have a set. Clarence Quote
75_M20F Posted July 30, 2017 Report Posted July 30, 2017 If you have electric gear you only need the tool for the main gear? Is that correct? Quote
Guest Posted July 30, 2017 Report Posted July 30, 2017 14 minutes ago, Mooney_Mike said: If you have electric gear you only need the tool for the main gear? Is that correct? You are correct. Â The nose tool is only required on manual gear model. Â For electric gear models you need a vernier caliber to measure spring compression. Clarence Quote
75_M20F Posted July 30, 2017 Report Posted July 30, 2017 55 minutes ago, M20Doc said: You are correct. Â The nose tool is only required on manual gear model. Â For electric gear models you need a vernier caliber to measure spring compression. Clarence Thank you! Quote
autoalain Posted July 30, 2017 Report Posted July 30, 2017 Hi,  one tool for main and one for nose,  thats  all,  but to be real honest I do not use them, I know many people will faint, but I do it by feel,  the tools have not left my box in 30 years. Quote
Sabremech Posted July 30, 2017 Report Posted July 30, 2017 15 hours ago, philipneeper said: Whats your $ for the tools? Â @Sabremech $245 for a set. If you just need the main gear tool, $150 for that one piece. Thanks, David Quote
RobertGary1 Posted July 31, 2017 Report Posted July 31, 2017 If you are only slightly industrious and have some ability to do metal work you can replicate the main tool pretty simply. I have no idea what the nose gear tool looks like though since mine is electric. Â -Robert Quote
philipneeper Posted August 4, 2017 Report Posted August 4, 2017 i have access to a machine and sheet metal shop. If someone would mail me specs id be happy to try for a home made one.  Quote
Sabremech Posted August 4, 2017 Report Posted August 4, 2017 17 hours ago, philipneeper said: i have access to a machine and sheet metal shop. If someone would mail me specs id be happy to try for a home made one.  I guess it all depends what your time is worth. 2 Quote
Guest Posted August 4, 2017 Report Posted August 4, 2017 I have 2 sets, if I didn't have them and needed some I know who I would call. Clarence Quote
RLCarter Posted August 4, 2017 Report Posted August 4, 2017 3 hours ago, Sabremech said: I guess it all depends what your time is worth. A dime holding up a dollar, way easier to buy it Quote
Hank Posted August 5, 2017 Report Posted August 5, 2017 2 hours ago, RLCarter said: A dime holding up a dollar, way easier to buy it Some of us make things for fun, not because it's cheaper. Challenging items are often more fun to make. Â 1 Quote
philipneeper Posted August 5, 2017 Report Posted August 5, 2017 Hmmmmm, Â i have a KY education, Im already challenged enough.... Quote
RLCarter Posted August 5, 2017 Report Posted August 5, 2017 1 hour ago, Hank said: Some of us make things for fun, not because it's cheaper. Challenging items are often more fun to make. Â Trust me I know...with a Lathe and a Mill in my garage top that off with people saying I cant do something has kept me up late more than once 2 Quote
philipneeper Posted August 5, 2017 Report Posted August 5, 2017 4 hours ago, M20Doc said: I have 2 sets, if I didn't have them and needed some I know who I would call. Clarence Whats the chances i can borrow one for a hit minute?  Quote
Guest Posted August 5, 2017 Report Posted August 5, 2017 8 hours ago, philipneeper said: Whats the chances i can borrow one for a hit minute?  Sadly, slim to nil, they are needed to run my shop. Clarence Quote
