Larry Posted March 3, 2017 Report Posted March 3, 2017 (edited) I know that these are more durable, but are they Mil-Spec? IOW, what is the IA going to say at annual? Edited March 4, 2017 by Larry Error on original post
FloridaMan Posted March 5, 2017 Report Posted March 5, 2017 I intend to start using blue painters tape over my fuel caps when I stop, with fueling instructions written on them. Last time in Key West, Signature didn't install my cap correctly and I ended up with nearly a quart of water in the tank. After sumping til I couldn't get any more water out, I started on the "good" tank, did a bunch of hard S-turns on the taxiway, sumped more water out of the tank. Left my passengers behind, took off, flew over the field, switched tanks and flew the airplane hard, switched back the good tank, landed, picked up my passengers, took off and headed home.
Badmoonraising Posted March 5, 2017 Author Report Posted March 5, 2017 Wow, interesting talk generated over a simple rain cap. I think I will continue to use this little gizmo and use the original O-ring. The issue to me is to prevent water from getting in there in the first place. Additionally, I am located in Kelowna, B.C.. We have had a more sever winter than usual this winter. Sever or not we alway have freezing temperatures in winter an if water pools around the fuel cap it will freeze and expend. Freeze-thaw-freeze-thaw... Seems better to just keep water out. We've a simple people in Canada. If you don't like what's on TV. We turn the TV off 2
milotron Posted March 5, 2017 Report Posted March 5, 2017 Late to read this thread but should have done so sooner after picking ice out of the fuel cap so I can open it. Going to put these in place today hopefully simplifying tomorrow's early departure. This is a fantastic idea and am going to do the same. Another simple Canadian on the wet (and unusually cold) west coast. It is snowing again...what's up with this winter? 1
Badmoonraising Posted March 5, 2017 Author Report Posted March 5, 2017 Milotron: I did much of my training in Victoria. Please plan to attend COPA in Kelowna this summer. I still have property on Pender Island. Shame they closed the strip. It was on of the factors when buying there. Not that our Mooney's are the ideal aircraft for that mission!
milotron Posted March 5, 2017 Report Posted March 5, 2017 Will do what i can Badmoon. Between work and family, Mooney time is what tends to give way. I'll check out the schedule and plan for it. Kelowna/Penticton is fantastic in the summer but getting accommodations can be the challenge. iain
RobertGary1 Posted March 6, 2017 Report Posted March 6, 2017 On 3/4/2017 at 4:50 PM, Antares said: I intend to start using blue painters tape over my fuel caps when I stop, with fueling instructions written on them. Last time in Key West, Signature didn't install my cap correctly and I ended up with nearly a quart of water in the tank. After sumping til I couldn't get any more water out, I started on the "good" tank, did a bunch of hard S-turns on the taxiway, sumped more water out of the tank. Left my passengers behind, took off, flew over the field, switched tanks and flew the airplane hard, switched back the good tank, landed, picked up my passengers, took off and headed home. That's concerning. It sounds like you may have a plugged rib drain that is allowing water to pool behind a rib and not run down to the drain. Any water entering the system should have an unobstructed path to the drain. There is an SB for that. http://www.mooney.com/en/sb/M20-230A.pdf -Robert
FloridaMan Posted March 6, 2017 Report Posted March 6, 2017 It wasn't much. Maybe 1-2 oz after the taxi. That may have been enough to have been stuck to rivers. Paul did the tanks 7 years ago. Sent from my iPhone using Tapatalk
