gsxrpilot Posted December 8, 2016 Report Posted December 8, 2016 Does anyone know where I can get one, or if such a one exists? I'd like a switch to fit in the blank spot, next to the Prop De-ice, and be marked Avionics Master.
kortopates Posted December 8, 2016 Report Posted December 8, 2016 There is a Mooney Radio master switch retro-fit kit. It's not a Klixon CB switch but a toggle, like the gear switch, usually installed at the top of the right hand side.Doing this is more than a switch though. A relay is used so that it fails with the avionics always on rather than introducing a single point of failure. But these days modern avionics don't need an avionics switch. Current production just has a master switch. So probably not worth the expense to do it right.Sent from my iPhone using Tapatalk
TWinter Posted December 8, 2016 Report Posted December 8, 2016 Paul, What's the amp you need? I sold a few about a month ago on EBay. I think had a few left-over if I can find them. Mine were all black though. I also thought I saw a master on EBay a while back. -Tom
kpaul Posted December 8, 2016 Report Posted December 8, 2016 1 hour ago, TWinter said: Paul, What's the amp you need? I sold a few about a month ago on EBay. I think had a few left-over if I can find them. Mine were all black though. I also thought I saw a master on EBay a while back. -Tom Tom, I am in the need for one switch to replace my pitot heat. it shuts off after a minute or so. I need to check the amps on it.
TWinter Posted December 8, 2016 Report Posted December 8, 2016 22 minutes ago, kpaul said: Tom, I am in the need for one switch to replace my pitot heat. it shuts off after a minute or so. I need to check the amps on it. I'll see if I can find what I had leftover tonight.. -Tom
