1 hour ago, Marauder said:
In some regards, just tuning two VORs to the radials was easier. It is the flight plan disruption is what I am trying to check on. I think once you are on it, you're golden.
In most cases, as the Jeff Van West/IFR Magazine/AvWeb video points out, the "airway" will be in your flight plan to begin with since it was was probably part of your clearance or loaded as part of a SID. And, as Bob points out, most of the time, you will be given a heading to intercept. If not, you can, of course, ask for one and solve the problem that way. In that case, it's a simple matter of getting there and having automatic sequencing take over. At worse, you can activate the appropriate leg and have the 400/500 or 600/700 create the intercept.
What you kind of need to do is create the scenario you want to test and run in on the simulator to see how it works.
  • 2 weeks later...
On December 18, 2015 at 9:36 AM, daver328 said:
For a new GNS user ... That video was very informative! Thanks for posting.
Learning the OBS feature helps too if you have an unpublished hold.
Tim
