Took off from Brampton (CNC3) with a 30 knot tailwind to make it to Montreal (CYUL) in 1:50.  In the soup for the last 50 miles or so.  No problem and a rejuvinating approach in IMC.
Coming home??  That was a different story.  The 150 mile wide belt of various types of cloud had moved west so when I took off to return home (about 4 hours later) I went straight into the soup, into a 30 knot headwind.  Finish the climb to 8000' and while the airspeed indicator was Vno (150 mph - 130 kts), the GPS read 89kts for groundspeed.  Yup, you read it right.  I looked at the GPS and felt I was back in a 152.
Took three hours to make it back.  At one point I asked ATC to change the flight planned altitude to 6000' for the "ride."  Read "lower headwind."  Best groundspeed I made at all was 130 kts.  And that only lasted about 15 minutes.  Most of the time it was between 110 and 120.
Sheesh....
it's all relative.  I flew back from Hilton Head in a 180 Cherokee and the GPS read 67 knots groundspeed.  It's frustrating to see cars moving faster than you.
Four hours to get back from North Adams MA to Ohio yesterday. At one point I had a sustained groundspeed of 103kt, and was truing at 148. Tried dropping from 8500 to 6500 and went even slower. Last time I say "eh... gas is expensive here and there's only a predicted 30 knot headwind... 45 gallons should do it."
The cruel joke was a 172 and I called in landing from 15 mles out (he from the west and I from the east) at the same time and he was down, off the runway and shutting down before I was even in the pattern.
