Brandontwalker Posted September 22, 2015 Report Posted September 22, 2015 I am searching for two transistors to use on the glareshield dimmer. The part is a Delco 2N3079. I have scoured the internet and have been unable to find a replacement. Does anyone know of a supplier that carries these, or of an alternate part number that can be used as a replacement?
flyboy0681 Posted September 22, 2015 Report Posted September 22, 2015 The transistors in our dimmer bit the bullet and we landed up replacing it with a used unit. Damage: $450
Sqrtree Posted September 22, 2015 Report Posted September 22, 2015 Check with American Microsemiconductor, Inc. Their website shows stock but may have to call.
Brandontwalker Posted September 22, 2015 Author Report Posted September 22, 2015 I will check with American. $450 is a bit more of a tab than I was looking at to get the lights to dim again...
flyboy0681 Posted September 22, 2015 Report Posted September 22, 2015 I will check with American. $450 is a bit more of a tab than I was looking at to get the lights to dim again... In our case the lights were out cold.
jetdriven Posted September 22, 2015 Report Posted September 22, 2015 (edited) we used these and soldered them to the wires, and screwed them to the metal inside as a heat sink. http://www.mouser.com/ProductDetail/ON-Semiconductor/MJH11020G/?qs=%2fha2pyFadugdynM374%2f%2bCq7N6bqnSsGwghLdQHrB59ZdBqo9E6RF1Q%3d%3d these appear to be available again, they werent when I blew mine up. http://store.americanmicrosemiconductor.com/2n3079.html?gclid=CJbjyNqO6qcCFRFU7Aod6kJfcQ&mobify=0 Edited September 22, 2015 by jetdriven
tony Posted September 23, 2015 Report Posted September 23, 2015 Cross-reference Search Result (Equivalent Transistors) Mat Struct Pc Ucb Uce Ueb Ic Tj Ft Hfe Caps 1. 2N2580 Si NPN 150 400 400 5 10 150 2 10 TO36 2. 2N2580M Si NPN 150 400 400 5 10 150 2 25 TO36 3. 2N2581 Si NPN 150 400 400 5 10 150 2 25 TO36 4. 2N2582 Si NPN 150 500 500 5 10 150 2 10 TO36 5. 2N2583 Si NPN 150 500 500 5 10 150 2 25 TO36 6. 2N2584 Si NPN 150 600 600 5 10 150 2 25 TO36 7. 2N2585 Si NPN 150 600 600 5 10 150 2 25 TO36 8. 2N3079 Si NPN 150 200 200 5 5 150 0.05 7 TO36 9. 2N3080 Si NPN 150 300 300 5 5 200 0.05 7 TO36
Brandontwalker Posted September 23, 2015 Author Report Posted September 23, 2015 Thanks everyone for the help. I ordered some yesterday. The new ones, referenced above, appear a bit different because there is no screw out of the bottom of the transistor like on the original. It will take a bit of work to get it fit into place.
