I (think) I know where most items are but I have trouble seeing where the voltage regulator is in an early J model
 Anyone has an idea where it is located ?
In my 77J (SN 284) it was inside on firewall upper right. The landing light ground was  attached to the same screw as the regulator . The original was an OECO . I used a Zeftronics 15300 with an adapter (patch cable) . The 1530B has the right connector for the OECO but is not "elgible" for the M20J (BS -same box) If you want to move the regulator in a more convenient place the patch cable affords that and the 15300 is a bit cheaper. I put mine where the original was. Have been very happy with it.
Paul 77J KIKV
