Circuit Braker Question
I have a UBG-16 installed that I would like to have on its own 5 amp circuit braker and would like to add a dimmer that uses a 1 amp CB. Can someone enlighten me as to where I can find these at cheap bastard pricing for a 68C? I checked Spruce and they start at 30 bucks. Also, Spruce had different flavors to choose from. Can someone tell me which type is appropriate for the 68C?
Link to comment
Share on other sites
The mid-60s "C" models used Klixon PSM-xN series breakers, per the Electrical Equipment List in the Maintenance Manual.
If you search for a PSM-5N you can find it at Aircraft Spruce for $110 but it is not a stocked part.
I'd suggest the Klixon 2TC2-5 for a pull-able version, ~$20.
When I re-did the avionics in my "C" I used all new breakers of this series.
http://www.sensata.com/klixon/circuit-breaker-aircraft-2tc.htm
Link to comment
