Anyone know if you can swap the old six pack gauge cluster for the strip gauges WITHOUT messing with the probes?  Is the connector inter-changeable?  Thanks for reply.  Just thinking if I re-do right panel the strip gauges would take less real-estate accross the top...
Scott:
That is something I have thought about as well.  I met someone once who did just that, but I did not get any details from them and I have since lost contact.  But it is still attractive to me.
That is, right up until I can afford TSO engine management glass which will replace all of them as primary.
I already have digital exhaust gas and cylinder temp (multi-probe)...so will probably go EI Tach and Manifold gauges to supplement my already installed EI volt and fuel flow...can't justify install of glass for oil temp/pressure...I sump my tanks for fuel and use time/actual burn vs. fuel gauges...I just don't use the gauges in plane...DON'T TRUST 'EM.
I hear you...I bought the EI digital fuel flow and had wire run to GPS.  I am installing at annual with new tires/tubes, brake rotation, pads and brake cylinder and hydraullic gaskets a new...Looking forward to superior stopping power...again and knowing the exact fuel flow at different power settings...but NOT enough to rush fall.  November in Iowa will come soon enough anyway!Wink
  • 1 month later...
I switched to a strip guage when I did the SWTA panel mod on my B , and the senders were all the same , I know for a fact that all mooney fuel senders are the same , and the engine senders are lycoming parts , I have a spare strip guage for a 78 201 if any one wants it...
L.O.L...I have same tires and pads since I bought over 400 hours ago.  Tires are the real reason (and doing the brake rotation) and the flap pump handle needs new gaskets (over 40 years and it's leaking).  I just returned from northern Wisconsin.  Fastest trip ever.  Did 400 miles in under 2 hours (1.97) 8500 feet.  162 knots ground speed in cruise and 50 degrees rich of peak.   Sumped tanks.  Fuel usage of 22 gallons total.  Not bad.
