aaronk25 Posted September 21, 2012 Report Posted September 21, 2012 So I have a bad spark plug terminal cap, due to over tighting. Can it be replaced and the end of the wire be fitted with a new rubber insulator and conductor spring or do I need a whole 4 new plug wires with harness and mag cap, I hope not. Basically I over tightned it and it sucked the spark plug end threw the terminal cap. Quote
The_Wrench Posted September 21, 2012 Report Posted September 21, 2012 Yes, it can be replaced very easily. You just need the right tools. A good shop can do this for you. Quote
carusoam Posted September 21, 2012 Report Posted September 21, 2012 Welcome aboard to the_wrench, Your technical knowledge/details are deep. Best regards, -a- Quote
fantom Posted September 21, 2012 Report Posted September 21, 2012 Welcome aboard to the_wrench, Your technical knowledge/details are deep. Best regards, -a- No insult intended, but how do we (you) know that? Wrench has posted zero information about himself. Quote
carusoam Posted September 22, 2012 Report Posted September 22, 2012 Gary, It were two details that reminded me of trouble I had in the past. He is new here, I believe. So I went with welcome aboard... I hope he stays around and can offer more, and maybe introduce himself. Where's that link where we introduced ourselves? That fell to the back of the pile somewhere... Best regards, -a- Quote
aaronk25 Posted September 26, 2012 Author Report Posted September 26, 2012 Got the terminal cap fixed, local mechanic had a harness and was able to fix, not a big issue. Thanks! Quote
