Someguy Posted April 30, 2025 Report Posted April 30, 2025 Does anyone have access to the overhaul and maintenance manual from aero force. My turbo is leaking oil out of the compressor side into the intake system. I don't really want to spend the 625 dollars on the manual only to find out I need special tooling to complete the job. 400600-0000 E Aircraft Turbocharger Overhaul & Maintenance
LANCECASPER Posted April 30, 2025 Report Posted April 30, 2025 The top maintenance shops in the country don't overhaul turbos on airplanes that they maintain. They send them out to people that do this everyday, that have the equipment and the tools, have an inventory of parts, and the test equipment to make sure they got it right. If what you're trying to do is overhaul this yourself, that would not be wise. The premier shop that you'll hear over and over is Main Turbo. https://www.mainturbo.com/ 1
N201MKTurbo Posted April 30, 2025 Report Posted April 30, 2025 Usually, if the turbo is leaking into the compressor or turbine housing, it is because of a bad check valve. Take apart and clean the check valves before you do anything with the turbo. 3
philiplane Posted May 1, 2025 Report Posted May 1, 2025 the check valves in the turbo oil supply system keep excess oil from leaching past the turbo bearing upon shut down. These valves require service from time to time. When they don't seat due to small bits of debris, you get oil in the induction system and in the tailpipe.
Someguy Posted May 1, 2025 Author Report Posted May 1, 2025 I did remove and clean both of the check valves. The supply valve spring was intact. That spring offered little resistance to the flow of oil but still closed. However the return valve, (the one with the little flapper door) the spring was there but it would open under its own weight if held upside down. Which points me in that direction as to the cause of the oil in the inlet. The other problem is that check valve is anywhere from $1250-$1500 new P/N=641068. All I need is a spring. Does anyone have information as to where to find that spring or overhaul the check valve? It seems ridiculous to pay 1250 for a whole new valve when I'm being held back for a $5 spring. For now I have positioned the valve so that the hinge is at the 12 o clock position and will close under its own weight. I'll run it up tomorrow and update on the results. 1
N201MKTurbo Posted May 1, 2025 Report Posted May 1, 2025 https://www.springsfast.com/products/torsion-springs/?utm_source=Google Search&utm_medium=Paid&utm_campaign=Torsion&utm_term=small torsion springs
Bigdaddie Posted May 1, 2025 Report Posted May 1, 2025 I've been looking at this place. You'd have to take the stance that you don't know how it got fixed. I haven't checked in a while, but arn't the clamps like gold these days? http://www.turbo-power.com/
N201MKTurbo Posted May 2, 2025 Report Posted May 2, 2025 On 5/1/2025 at 8:54 AM, Bigdaddie said: I've been looking at this place. You'd have to take the stance that you don't know how it got fixed. I haven't checked in a while, but arn't the clamps like gold these days? http://www.turbo-power.com/ You can buy clamps from the race car guys all day long for about $30. Getting the clamps that say PMA on them is the issue.
Bigdaddie Posted May 4, 2025 Report Posted May 4, 2025 On 5/2/2025 at 9:31 AM, N201MKTurbo said: You can buy clamps from the race car guys all day long for about $30. Getting the clamps that say PMA on them is the issue. What about a field approval to use replacement clamps. I know, not going to happen...
N201MKTurbo Posted May 4, 2025 Report Posted May 4, 2025 14 minutes ago, Bigdaddie said: What about a field approval to use replacement clamps. I know, not going to happen... You might make a case that they are standard parts. The racing clamps are built a lot sturdier, out of thicker material. I think the aviation clamps were built to be as light as possible, because they are aircraft parts. https://shop-us.garrettmotion.com/spare-parts-v-band-clamp-560-gtx47-gtx50-gtx55-gen-i-gen-ii/p
M20F Posted May 14, 2025 Report Posted May 14, 2025 On 4/30/2025 at 1:51 PM, LANCECASPER said: The premier shop that you'll hear over and over is Main Turbo. https://www.mainturbo.com/ Second this.
geoffb Posted May 22, 2025 Report Posted May 22, 2025 (edited) If the bushings are tight and no significant axial play, it's a check valve. I went through the same thought exercise of replacing the spring, blah, blah. I needed it fixed. Bought a check valve. No issues now. worst part is dealing with the adel clamps. Edited May 22, 2025 by geoffb 1
Someguy Posted June 7, 2025 Author Report Posted June 7, 2025 Sorry it took so long to respond back. While I was dealing with that check valve and doing other maintenance (cylinder change) I found out my Camshaft is TOAST!! Now the engine is torn apart and I'm getting parts yellow tagged for assembly. Ive been looking at converting the LB to an MB, but can't really find any information online as to exactly what exact parts I need to get to accomplish this. From what I've read the STC holder passed. Anyone have any information?
Z W Posted June 8, 2025 Report Posted June 8, 2025 As far as I know, the "262" conversion to put a TSIO-360-MB engine on a 231 M20K is unavailable. STC is owned by a guy in Florida who doesn't respond to inquiries. Every few years there's a thread on here about people wanting to acquire it / bring it back.
Pinecone Posted June 9, 2025 Report Posted June 9, 2025 I don't think there is a path to convert an -LB to a -MB. You can convert an -MB to a -SB. The STC is to purchase an -MB and install it in place of the -GB or -LB. AFAIK the A-GB and -LB have the older intake manifold setup of the log style. The -MB and -SB have the tuned equal length runners. -GB/LB -MB/SB 1
geoffb Posted June 9, 2025 Report Posted June 9, 2025 (edited) both STCs to install a -MB in a 231 are orphaned and I can't imagine finding a 252 cowling in any case. Entire intake and exhaust are different. Cylinders are different. Maybe more. Edited June 9, 2025 by geoffb
