Souhail Posted April 20 Report Posted April 20 Hello, New to the Forum, Mooneys and with a fresh PPL, I can't find what this "ENCODER" ON/OFF button does on the POH (Check attached picture). Thank you. Quote
Souhail Posted April 20 Author Report Posted April 20 Thank you for your quick reply Here's the transponder I have. I guess the button is not doing anything compatible with modern transponders right ? Quote
Elijah Posted Thursday at 09:52 PM Report Posted Thursday at 09:52 PM That transponder requires an altitude encoder so I'm sure you still have one in the panel somewhere. I also think those transponders can display the altitude the encoder is sending, I'd turn off the encoder switch, power everything up and see if the transponder still displays correct pressure altitude. Then you'll know if that switch is doing anything or not :-) Quote
Souhail Posted Thursday at 09:54 PM Author Report Posted Thursday at 09:54 PM 1 minute ago, Elijah said: That transponder requires an altitude encoder so I'm sure you still have one in the panel somewhere. I also think those transponders can display the altitude the encoder is sending, I'd turn off the encoder switch, power everything up and see if the transponder still displays correct pressure altitude. Then you'll know if that switch is doing anything or not :-) Thank you! I'll give it a try to check. Quote
