This is not the clamp for the turbo, but is the Lycoming part # 12093-5 for the bypass  (Item number 11 in the diagram).
The turbo clamp needs to be the riveted version, but this one does not need to be a riveted version, nor is a riveted version made. When rebuilding the exhaust system it's good to used new clamps so that you start everything with known parts.  The service bulletin (20-283A), which requires the turbo v-clamp to be riveted,  mentions, "The other two Vband clamps used to connect the by-pass pipes have not had a history of becoming loose or failing."  That is the part that is for sale. This is new in the package and has never been used.
Aircraft Spruce sells these for $518.00 each https://www.aircraftspruce.com/catalog/eppages/lycomingcouplings_07-16014.php
SOLD
  • LANCECASPER changed the title to Lycoming V-Band Clamp for bypass pipe M20M - SOLD
