Does anybody know who can service a turn coordinator for a Brittain autopilot?  It’s a tc100 Evs.   Tried porter strait in Tulsa and they don’t service them anymore.   Thanks.
Try contact Kevin Westbrook. He was working for Brittain for years and still helps people on the list. Good luck.
[mention=48565]Kevin Westbrook[/mention]
Yes, Kevin used to work for Brittain, building their turn coordinators. These are NOT diy fixit units, so get a professional to fix it. He can fix them but not provide a yellow tag.
Sent from my SM-A526U using Tapatalk
Yeah, trust me.  I tried to repair one my self.  As soon as I realized I also had to build a rig to "turn" the coordinator 360 degree with exactly 2 minutes, I say, forget it!!  I should let professional handle it.  Keven did great work in bring it back alive!!
7 hours ago, N201MKTurbo said:
You could build a rate table for about $100 on Amazon.
Interesting.....
Searching or Rate table come up with nothing.  Are you referring to buying parts for DIY rate table?  Care the share a picture if you made one?
1 hour ago, N201MKTurbo said:
I looked a bit, you can get 5 RPM 12V gear motor for $50. you will need to make some type of turntable and a 10/1 belt drive. I would get a lab power supply to fine tune the speed. You can calibrate it with a stopwatch.
Or you can spend big bucks:
https://www.ideal-aerosmith.com/products/1-2-or-3-axis-rate-and-positioning-tables/
Some of you here are way beyond the norm while the rest of us are still hammer, tong and forge!
