mikey757 Posted January 12, 2025 Report Posted January 12, 2025 Has anyone done an overhaul recently on a J and care to elaborate on the total cost? R&R cost? Shop used? Other equipment changed during the process?
DCarlton Posted January 12, 2025 Report Posted January 12, 2025 Back in 2015-2016 it was $32K for me total for an IO360 including R&R and a firewall forward refresh. Guessing you're up to $40-45K total now. https://www.coronaengines.com/Engine-Overhaul https://www.coronaengines.com
jetdriven Posted January 12, 2025 Report Posted January 12, 2025 The engine itself it going to be nearly 40K, and some shops will be over that. Then the rest. 1
1980Mooney Posted January 12, 2025 Report Posted January 12, 2025 (edited) 4 hours ago, mikey757 said: Has anyone done an overhaul recently on a J and care to elaborate on the total cost? R&R cost? Shop used? Other equipment changed during the process? 1 hour ago, jetdriven said: The engine itself it going to be nearly 40K, and some shops will be over that. Then the rest. “the rest” can be significant. A Mooney owner at Fullerton posted these costs in addition to the cost of the engine overhaul early last year: Freight to/from $ 2,580 Prop Overhaul $ 3,873 Governor Overhaul $ 880 Oil Cooler Overhaul $ 554 Misc Parts $ 1,683 Labor $ 7,345 If they find issues with your exhaust (likely) then add about another $2,500 -3,000 for repair and freight. That adds about another $20,000 on top of just the bare engine overhaul cost. So maybe $60,000 all in….give or take a few thousands. If you go with a Factory OH or Rebuild add the appropriate delta on top. Edited January 12, 2025 by 1980Mooney
Gee Bee Aeroproducts Posted January 12, 2025 Report Posted January 12, 2025 Baffle seals 275.00 Sceet Ducts , price depends on model Teflon hoses black or blue firesleeve/ tso let me know if you need something made .
1980Mooney Posted January 12, 2025 Report Posted January 12, 2025 (edited) @mikey757 The standard oil/fuel hoses, if aged and stiff, could add a another $thousand or so. Don’t know what Teflon ones above cost. Some replace the throttle cable depending on age. Also once the engine and engine mount frame is off, it is not uncommon to discover some corrosion on the engine frame. The tubulars are thin and tolerances are extremely small. You may want it powder coated if repaired. Shipping and repair can add up to another couple $thousand. In an earlier discussion someone said that they don’t like to total it all up because it is too depressing …. Edited January 12, 2025 by 1980Mooney
Ryan ORL Posted January 12, 2025 Report Posted January 12, 2025 Base IO-360-A3B6 OH cost (March 2024) was $40k plus or minus $1-2k (based on at least 8 shops I got quotes from). That assumes reusing basically everything and OH’d cylinders. Standard turnaround time 14-18 weeks plus or minus. I opted for a new camshaft and new (PMA) cylinders, plus freight and a couple minor extras. $48k for the engine shop altogether. Paid to expedite and got it in 4 weeks. I spent $14k on the rest… removing and reinstalling the engine, new everything (mounts, hoses, etc), overhauling my governor, etc etc etc.
ArtVandelay Posted January 12, 2025 Report Posted January 12, 2025 I replaced all the control cables, they were original and I thought 40 years was enough.New alternator,refurbished all the baffling, just flushed the oil cooler since it had been replaced, repainted the engine mount. Some work I did myself to lessen the cost.I also had prop overhauled.I had to replace the case because it was cracked, probably because PO installed a non approved 130 amp alternator.I didn’t keep track of the all the costs, but it was close to 40k.Zephyr did mine, I didn’t have to pay shipping because I was close enough for them to send a guy to pick it up. And being Florida there was no sales tax.
201Steve Posted January 12, 2025 Report Posted January 12, 2025 @Ryan ORL curious what shop you used that got it done so fast? That’s a compelling reason to pick
Ryan ORL Posted January 13, 2025 Report Posted January 13, 2025 7 hours ago, 201Steve said: @Ryan ORL curious what shop you used that got it done so fast? That’s a compelling reason to pick Certified Engines Unlimited in South Florida. $1500 expedite fee. To be fair they only promise 8 weeks for that but they got it done in 4. 1
mikey757 Posted January 13, 2025 Author Report Posted January 13, 2025 Thanks for all the info. Very helpful
