warrenehc Posted Monday at 03:02 AM Report Posted Monday at 03:02 AM Hello, new owner here. Is the rudder trim on the panel tied to the KAP 150, or is that ran independently? Asking because I’m looking to upgrade my autopilot. Quote
Fritz1 Posted Monday at 03:37 AM Report Posted Monday at 03:37 AM I have a KFC225, took it out for repair and flew the plane home without it, elevator trim did not work, but rudder trim did, KAP150 most likely the same Quote
Fly Boomer Posted Monday at 04:44 PM Report Posted Monday at 04:44 PM 13 hours ago, Fritz1 said: I have a KFC225, took it out for repair and flew the plane home without it, elevator trim did not work Do you mean the Manual Electric Trim (on yoke) did not work? Quote
LANCECASPER Posted Monday at 05:15 PM Report Posted Monday at 05:15 PM 14 hours ago, warrenehc said: Hello, new owner here. Is the rudder trim on the panel tied to the KAP 150, or is that ran independently? Asking because I’m looking to upgrade my autopilot. Rudder Trim has no connection to any autopilot on a Mooney. A Yaw Damper, if installed, would. Quote
Fritz1 Posted yesterday at 02:23 AM Report Posted yesterday at 02:23 AM Yes, electric joke elevator trim goes through the autopilot and is disabled when autopilot is un-installed, aircraft is legal to fly when correctly placarded Quote
PilotX Posted 12 hours ago Report Posted 12 hours ago Assuming you upgrade to the GFC500...rudder trim will fight the YD on the GFC500. Meaning if you turn on the AP in climb and then in cruise you don't disconnect the YD and center the ball again, the YD will (may) eventually disconnect the AP until you fix it, I have gotten to where I shut off the YD and just center the ball using rudder trim. Quote
