Z W Posted January 3 Report Posted January 3 Background - it came up in another thread last year that new factory-style Mooney baggage door seals were hard to source. The Knots 2 U ones sold on Spruce and other places are made of cheap weatherstripping foam, are not factory style, and instead of attaching to the door, they go on the airframe, and therefore get scraped/damaged easily as you load and unload baggage from the plane. I'd been through several of those, with the last one not even lasting two years, when I complained here. @Gee Bee Aeroproducts stepped up, I believe bought a salvage baggage door, and manufactured a new factory-style seal out of modern high-quality silicone. I think I bought the first one. Shame on me, it took me a few months to get around to getting it on the plane, and a couple more months to post this, but it's there now. Report: The seal is great. Arrived with enough seal material to make a little more than two of them and a nice clear 2-part epoxy to glue it on. It makes a much tighter fit than the foam seal did, such that I had to lubricate the lock pins to get it to close. At first I was worried it was too tight, but after a little grease on the pins, it closes smoothly and is very snug. Before, the latch felt like it could pop open in flight if not locked. Now, I still lock it, but there's no way it's coming open unintentionally if I were to forget. I've never had a factory style seal, so I'm not sure, but suspect it's working as intended now. I also never had problems with water intrusion before, but I'm certain it seals better and tighter now. It's been on for a couple of months and has not compressed or loosened much, which is perfect. It's safe and out of the way on the door and I don't expect it to get damaged or need replacing any time soon. Thanks Guy for making a great new product for our Mooneys. A few pics below. 10 Quote
Slick Nick Posted January 3 Report Posted January 3 Nice review. Is it “P” shaped like the stock one? Almost looks like you have it on backwards, with the flat part facing outwards instead of being tucked flush under the trim panel. 1 Quote
Z W Posted January 4 Author Report Posted January 4 The seal is P-shaped. The flat part would definitely not fit under my trim panel, which is trimmed way above the seal surface, though I believe my trim panel has been replaced, so I'm not sure how it came from the factory. The way it's in there fits and seals very well. I don't think the door would close if it were reversed - the thick part of the seal would be pushed out into the thinnest parts of the gap between the door and the fuselage. My parts catalog doesn't show the orientation of the seal. Anybody have a picture of a factory seal installation? Quote
Gee Bee Aeroproducts Posted January 4 Report Posted January 4 We reduced the seal in overall dimensions and reduced the duro to the softest spec . The first article copy of the original was the same dimensions as the B727 nose gear door seals , who copied who ? GB Thanx for the feedback I stock mu2 / and tbm door seals Quote
Gee Bee Aeroproducts Posted January 4 Report Posted January 4 Cabin and Baggage same seal Need something made , just ask Quote
Marc_B Posted January 4 Report Posted January 4 @Z W and @Gee Bee Aeroproducts, is this the newer profile of the seal or the older profile...I can't remember but think one was smaller and thicker and one was larger and thinner walled?? Which is the newer/improved? Quote
Gee Bee Aeroproducts Posted January 4 Report Posted January 4 (edited) The larger thicker P seal was the same dimensions of the nose gear door seals. I then reduced the seal size by 25% and thinner wall thickness for a revised seal -1 . GB Edited January 4 by Gee Bee Aeroproducts 1 Quote
Gee Bee Aeroproducts Posted January 4 Report Posted January 4 (edited) Here is a oem picture Bulb outward The bulb is flattened as its rubber after age, this will not happen in the silicone version. Edited January 4 by Gee Bee Aeroproducts 1 Quote
Z W Posted January 4 Author Report Posted January 4 OK then. Mine seals very well installed backwards, and looks like it was meant to go that way to fit into the shape of the fuselage frame. But you should probably install it like the factory did. Thanks for the photos Guy. 1 Quote
Slick Nick Posted January 5 Report Posted January 5 The little lip on the inside i think is designed to keep water out, since it makes a bit of a bend where the door does. The way your seal is installed might allow moisture in behind it. You ssid you had extra seal left over? Might be worth redoing it the proper direction. Quote
Gee Bee Aeroproducts Posted January 5 Report Posted January 5 I have plenty of seal in stock Remove all old cement with toluene mask both edges of seal apply clear silicone cement , let dry apply clear silicone cement to seal in 3/5 inch increments and dry with hairdryer. cure 18/24 hours before closure. Pressuried / inflatable seals always have a rain seal for when the aircraft is static and the seal is not inflated. This small rain seal 13ft long is over 3k dollars now . Next time you step into a Boeing or airbus you will notice the rain seal if you are looking. 1 Quote
Andy95W Posted January 5 Report Posted January 5 @Z W- thanks for the pirep. How much was the baggage door seal? Do you intend to do your door as well? Quote
Gee Bee Aeroproducts Posted January 5 Report Posted January 5 Cabin Baggage 325.00 pair with 4oz clear silicone cement option 1 Qt toluene 20.00 shipping to be determined n77gb@msn.com 1 Quote
Gee Bee Aeroproducts Posted January 6 Report Posted January 6 Anything, anytime Transducer bracket one week start to finish Quote
67 m20F chump Posted January 6 Report Posted January 6 I have used his products on all 3 planes I have owned. Always excellent quality and by aviation standards great prices too. Quote
Gee Bee Aeroproducts Posted January 6 Report Posted January 6 Need something made , let me know Caliper Bleed Cap silicone We molded 1000 each in Porsche atomic Green Red is the basic, similar to the Brembo bleed cap . I have a new three piston tso caliper coming soon and this is a subassembly Quote
Danb Posted January 6 Report Posted January 6 On 1/3/2025 at 10:55 PM, Z W said: closes smoothly and is very snug. Before, the latch felt like it could pop open in flight if not locked. Now Expand On 1/4/2025 at 1:53 AM, Gee Bee Aeroproducts said: Cabin and Baggage same seal Need something made , just ask Expand Geebee, I’ve had continuous issues with door seals on my Bravo and Acclaim didn’t have any issues on my two J models? I don’t like the fit on my Acclaim, only wish Mooney had made our frames properly no two seem alike nevertheless I had a popular MSC replace my seal and still don’t like the fit. The air seal on my Bravo was good but I’d rather not go that route on the Acclaim. How have your clients liked the passenger door seal you manufacture? On another front I wanted Rosen shades but there not available for the Acclaim? The knock offs I got from Don won’t stay put even though I’ve tried numerous screws. Thanks D Quote
Gee Bee Aeroproducts Posted January 7 Report Posted January 7 I made this seal twice , the second time reduced profile and durometer. There are two ways to install the same seal : apply with no stretch apply with a little pull This will change the dimension of the seal . There are no other manufacturers of door seals that will invest in perfection of a Seal . Would you tool for a molded seal with fabric per AMS3345 for 46k mold cost ? I did , 54 weeks later and all six molds were completed to mfg one seal . The reason for fabric is the seal is bolted to the airframe. I changed the color to a warmer gray vs bone white. Iam currently doing two sets of airstar seals for a B727-100Q to the customer color spec . please call if you have technical questions Quote
LANCECASPER Posted January 7 Report Posted January 7 On 1/7/2025 at 12:21 AM, Gee Bee Aeroproducts said: There are two ways to install the same seal : apply with no stretch apply with a little pull This will change the dimension of the seal . Expand Which is the correct way? I am guessing no stretch. Quote
Gee Bee Aeroproducts Posted January 7 Report Posted January 7 On 1/7/2025 at 12:25 AM, LANCECASPER said: Which is the correct way? I am guessing no stretch. Expand Thats depends on the tolerance in the door . Ref Beechcraft large gap, bulb on edge of door close tolerance, bulb on inside edge I hope this helps you understand how the seal and tolerance fit together. You can thin the Mooney seal by pulling it taunt during installation. Cement a small section first and let cure before installing the rest of the seal. start at the bottom and buttthe ends together. Silicone will not shrink with temperature or age . GB 1 Quote
