Howdy,
I’m currently looking into buying a 20J that is based in Indianapolis. I’ve tried to find a Mooney Service Center near by, but apparently the closest one is in Illinois.
Any recommendations for a good shop or A&P in the area?
Thanks!
Chris
Give Jeff Schnabel a call. Several others and myself can vouch for him. He's based a short drive or quick flight away in Cincinnati.
Mooney CFIs (themooneyflyer.com):
Jeff Schnabel,  (OH, IN, KY), based at Cincinnati Municipal Airport-Lunken Field (KLUK), Cincinnati, Ohio.  CFII, MEI, ATP, A&P.   5,000+ hrs exp. Owned a 201 for 18 years, currently flying Mooney Ovation, Bravo, 201 and 231 types. Over 2,000 hrs flying Mooneys.  Very experienced flying as well as  maintaining these birds.  And yes, I am a Mooniac. Email: schnabel79@gmail.com,  ph (513) 484-0604.
I used Anderson Aircraft Services/Keith Givens for pre-purchase inspection. Others recommended by the broker in Indianapolis area.
Edited by PeterRus
Hi, I purchased my Ovation 3 from IndyAir in May. I had, Chad Williams drive in and do the prebuy. He's a Mooney Specialist.
CHAD WILLIAMS, WILLIAMS AVIATION/ WILLIAMSAVIATION@ME.COM
I didn't have Anderson Aircraft do the prebuy because they had done the last few annuals. Chad was very good. Also, Jeff Schnable flew the plane back to Vegas with me. Great guy.
I'm sure Jeff would do a good job, as would Keith. I know Keith had been doing the ongoing maintenance of my O for a number of years and it is in fantastic shape.
I know of an experienced Mooney mechanic in STL and he personally owns a J. He’s busy, but might be down to travel. If interested I can connect you.
Thank you for the feedback, guys! Much appreciated.
I’ll reach out to Chad and Jeff. @bigmo can you put me in touch with the gentleman in STL?
@PeterRus and @catchman86 thank you very much for your input as well.
update: I just talked to Jeff and he’ll do the pre buy. Thank you again for your responses, Mooniacs! Let’s see how this plays out.
Edited by TxAviator
Howdy, y‘all.
We worked with Jeff Schnabel, and everything went great. Ended up buying our dream Mooney.
Thank y‘all for the help!
