Stan Posted October 1 Report Posted October 1 I am replacing my rebuilt (twice) Electrodelta VR 802 voltage regulator. The replacement is a (International Avionics Inc.) Mooney Part # 940170-501 which is a replacement for Mooney Part # 800270-501. The replacement VR is smaller than the VR 802 and a new bracket is needed. Has anyone done this and if so is there a drawing or sketch of the bracket, or does one fabricate one? Quote
KSMooniac Posted October 1 Report Posted October 1 4 hours ago, Stan said: I am replacing my rebuilt (twice) Electrodelta VR 802 voltage regulator. The replacement is a (International Avionics Inc.) Mooney Part # 940170-501 which is a replacement for Mooney Part # 800270-501. The replacement VR is smaller than the VR 802 and a new bracket is needed. Has anyone done this and if so is there a drawing or sketch of the bracket, or does one fabricate one? maybe 15 years ago I replaced my OEM VR (77 J) with a Zeftronics unit, and I don't recall replacing any bracket. Accessing the location is a PITA, however! Quote
Aerodon Posted October 1 Report Posted October 1 Are you talking about the shelf above the passenger's left knee? Mine was starting to look like swiss cheese because of all the different antenna splitters that had been mounted on the forward side. So I drew it and cut a new one on my CNC machine. This is an easy enough part to make by hand, but if you want something that looks like it came from the factory I can cut one for you. Aerodon Quote
KSMooniac Posted October 1 Report Posted October 1 Mine is on the right sidewall, behind the circuit breakers and close to the firewall. I know things like this moved around over the years, though! Quote
Stan Posted October 2 Author Report Posted October 2 Aerodon, thanks for the offer, but I'll make one myself. Thanks again! Quote
