Max Clark Posted September 13, 2024 Report Posted September 13, 2024 What is your post annual checklist? Are you taking panels off and inspecting yourself, getting under the plane, under the dash? Changes to your preflight, run-up? Any tips or tricks that you've picked up over time?
alextstone Posted September 13, 2024 Report Posted September 13, 2024 This is a helpful guide: https://www.faa.gov/sites/faa.gov/files/2022-01/Advanced Preflight After Maintenance.pdfAdvanced Preflight After Maintenance.pdf 2
Schllc Posted September 13, 2024 Report Posted September 13, 2024 The only two times I have had an annual and not de-cowled prior to flying off was my first and the last annual. After flying home, post first annual, I smelled a heavy oil smell when I landed. I removed the upper cowling and found a pile of rags under my oil filter. Every annual until the last one with Brian Kendrick I have de-cowled, started, runup, shutdown and reinspect. I have found a few minor things but nothing shocking. After the last annual I went through with Brian K. I did not bother because he test flew the plane three times prior to my pickup and his work is impeccable. I have also been fortunate enough to have great service with only a few surprises with all of my annuals except for one in Ft Lauderdale at KFXE, by a criminal enterprise, which most of you know but I will not name publicly. I will likely assist with all of my annuals from this point on, so hopefully the post annual inspection will be much simpler. 4
Hank Posted September 13, 2024 Report Posted September 13, 2024 Owner assisted annuals are the best, but are not an option with my new IA. They let me see everything, and participate in decisions, sometimes pointing out things to watch or to plan for next year. Now, I just have a thorough preflight, checking everything external and under the cowl carefully. Inside, I make sure my seat locks in place, then check the position of every switch and button in the cockpit. Then I make sure to.hit every item on every checklist from Pre-Start to Takeoff. Make one lap around the field, then a landing to full stop. THEN I fly home, all of 15 minutes from wheels up to pattern entry. Followed by a walk around and leak check. 2
redbaron1982 Posted September 13, 2024 Report Posted September 13, 2024 Regarding owner-assisted annuals, can anyone recommend a shop/IA in the Houston area that is okay with it? For my last (kind of first) annual, I tried to go this route, but all the shops that Savvy contacted were not open to get the owner to help with the annual.
Paul Thomas Posted September 13, 2024 Report Posted September 13, 2024 I've only gone through one annual/prebuy. I was present and confident with the work that had been done. I treat all post maintenance flights the same, whether it is an annual or something minor. During pre-flight, I pay special attention to the areas that have been working on or could have been affected by the work being done. If engine work has been done, I'm even more careful about oil pressure after start/watching temperatures. I like to keep my post maintenance flights to ~45 minutes. The big change in procedure for me is post flight: I'll check again the same areas I gave special attention during pre-flight. If the maintenance involved anything that could cause a leak, I will inspect that area again. Each fitting is checked with flashlight and a mirror because sometime you don't have a leak but just slight seeping around a fitting and something you wouldn't catch until the next annual. A post maintenance run-up normally catches those things but I like to double check and a 45 minute flight is more likely to show problems.
Fritz1 Posted September 13, 2024 Report Posted September 13, 2024 Highly recommend owner assisted annual, make it clear up front that you do not expect any discount, you will typically discover things that the AP/IA does not or does not deem important and you can fix them in addition to what he does, two sets of eyes see more than one, when decisions are to be made you are right there, it helps to bring bagels, cash and other valuable consideration, the best annuals I have ever had were with Brian Kendrick in San Marcos, he sees things that other people don't and he test flies the airplane what most A&P IAs are not able to do, he does not need any assistance, with most other A&P IAs assistance is helpful and welcome, sometimes you have to nudge yourself in, convince the guy that you will not cut into his profits and not cause any trouble but want to be part of the solution. Once a relationship is established the guy will work on your airplane instead of working on airplanes of owners that have pissed him off. 2 1
Fly Boomer Posted September 13, 2024 Report Posted September 13, 2024 4 minutes ago, Fritz1 said: Once a relationship is established the guy will work on your airplane instead of working on airplanes of owners that have pissed him off. I can be a much closer working relationship than any other service I can think of. Well, almost any. 1
DCarlton Posted September 13, 2024 Report Posted September 13, 2024 Based on experiences, I'd like to know and understand in advance what will be wrenched on or disassembled and why, and I'd like to be there for final inspection when that work area is closed out. I'm caring less about assisting these days, but I'd prefer complete awareness of what work is being done and what quality assurance steps are taken to make sure the work is done properly. Once bitten, twice shy...
Rick Junkin Posted September 13, 2024 Report Posted September 13, 2024 @Max Clark I referenced the guide linked by @alextstone above and, combined with what I've learned through my own experience, built post-annual checklists in Foreflight, stored last under the "Abnormal" tab. Unfortunately Foreflight doesn't provide a way to print or extract the checklists, only a way to share the entire checklist to another Foreflight user. I took screen shots of my checklists and am happy to share that way if you're interested and send me a DM. It's a checklist so only Big Rock items with little detail on the specific what's and how's. Here are the top level checklist subgroups, each with expanded checks beneath them. I have another 10+ pages of the underlying checks. 1
Joshua Blackh4t Posted September 13, 2024 Report Posted September 13, 2024 I work in a different field (construction) but I also get people asking if they can help. Obviously its a blanket no upfront. Anyone who asks if they can help is not likely to be helpful. Specify what you can help with and it gets better "may I be present so I can clean any panels that get pulled off, and maybe assist pulling off inspection panels. I'll bring my own tools". That will be a lot easier for a mechanic to allow. (In my case if someone asks if they can be there to sweep up and take away the rubbish, thats most likely to be accepted) Also, accept that the answer sometimes is no. They want to work in their timeframe, and it won't work to have you there. It comes down to personal trust. So you'd have to go there yourself and ask. Its a catch 22, if you don't trust them to work on it without you being there, they shouldn't trust you to be there either.
EricJ Posted September 13, 2024 Report Posted September 13, 2024 I think it's a lot easier for an independent mobile mechanic (which is mostly what we have around here) than an IA in a shop to provide owner assisted annuals. Having a customer banging around in a shop can definitely create issues, but if an IA goes to your hangar to do the inspection it's much easier to accomodate owner assistance. Another thing that makes it easier is if it is evident that the owner is reasonably handy with tools and is not going to do damage along the way. If you do some of your own maintenance, like oil and tire changes, etc., say so, as it'll convey that you may actually help things move along rather than be in the way. That said, some shops do allow owner assist, so it may be worth asking a shop that you'd like to work with. I suspect that sometimes when an IA says No to an assisted annual they're really saying no the individual rather than saying they don't do owner-assisted annuals.
Yetti Posted September 16, 2024 Report Posted September 16, 2024 Depending on how much was done. I will do one or two fast taxi. Then come back and check everything. Then circle up over the airport. land and check things. Then the bird is ready to fly.
jetdriven Posted September 16, 2024 Report Posted September 16, 2024 On 9/13/2024 at 10:22 AM, redbaron1982 said: Regarding owner-assisted annuals, can anyone recommend a shop/IA in the Houston area that is okay with it? For my last (kind of first) annual, I tried to go this route, but all the shops that Savvy contacted were not open to get the owner to help with the annual. Bob Wagstaff at K&W Aviation in Laporte Texas, T41. I worked out there with Bob and his crew for the better part of 10 years and they know Mooneys quite well. We learned together 1
Bart Chilcott Posted September 17, 2024 Report Posted September 17, 2024 In the 9 years of owning my Mooney, I’ve only had one annual that was not owner assist. That one and only time was at a premier Mooney service center. The aircraft was there 10 weeks and my post annual inspection revealed; 9 quarts of oil in an 8 quart IO 360, non functional toe brakes as the brake system had not been properly bled, pilots window hinges installed backwards, a Craftsman 9/16 wrench on the engine and two missing inspection plates from the bottom of the wings. With that said, I don’t have a specific post-annual checklist as I only do owner assist. However, from my experience, I believe it’s critical that you go beyond a normal preflight, as others have pointed out, and look it over THROUGHLY. 2 1
