Looking for help identifying the washer on our gascolator. Airight 51250. It’s not detailed in the Ovation IPC, and lasar could not find it either. I know they have the gasket kit, but the washer isn’t called out in that. My IA would like to replace as a it’s a little worse for wear (wallowed out hole and dinged up), it’s a pretty thin washer. It is located between the nut that holds the gascolator on. I can’t seem to locate a contact for Airight either.39c5e639283ee8bf7628a04591910f56.jpg
