28 minutes ago, AH-1 Cobra Pilot said:
What might your insurance agency say if it ever gets stolen?  "You made it so a thief did not need the key?"
Didn't seem to slow down the infamous Barefoot Bandit, who flew off and crashed several planes.
28 minutes ago, LANCECASPER said:
 Plus no turboprop or jet I've ever seen has an ignition key,.
When I was in the training command, a drunk sailor tried to steal a T-39.  He burned up a starter on the first one, but got the engines started on the second jet.  He originally tried to steal a T-47, but found out they had an ignition key.
I use a throttle lock when I'm away from my hangar.
Many GA aircraft are delivered without a keyed ignition. Citabrias and Decathlons have toggles on the upper left side switch panel. I don’t believe I have ever been in a light twin with a keyed ignition.
No key needed, just reach under the pull the wires off the ignition switch.   Plus, if you wandered around a Mooney gathering, I bet your key would work in at least 20% of the planes.  I remember reading one time that Ford only had 10 keys.
Was talking to my avionics shop, he recommended a Mags Off card that you would put on the glare shield.  When you put that out, you double check the switches.
We also brainstormed a circuit that would light an LED if the mags were Off (or maybe have it light when they are ON).
