M20F Posted February 29, 2024 Report Posted February 29, 2024 No matter the brand the wheels always get stuck on some small piece of FOD. 1 Quote
philiplane Posted February 29, 2024 Report Posted February 29, 2024 How much are the fragile discs in your spine worth, and possible loss of mobility from abusing them? That is the real question. Quote
Hank Posted February 29, 2024 Report Posted February 29, 2024 On 2/28/2024 at 5:47 PM, Mooneymite said: In keeping with the principle of "KISS" and being a true CB, I have used the cardboard from Chewy boxes to slide around on my epoxy floor. I hope to get trifecta points for cheap, simple and very low height. Congratulations, Gus! You have the lowest-cost creeper I've ever seen. The only way to beat that is to use someone else's box . . . . But in terms of surface prep for your creeper to work, you broke the bank, at least mine . . . . 1 1 Quote
hammdo Posted February 29, 2024 Report Posted February 29, 2024 I use a racer mat - about an 3/4" thick 6’x2’ - at the time it was $30 but now is $66: Quote
Marc_B Posted February 29, 2024 Report Posted February 29, 2024 11 hours ago, GeeBee said: I use two creepers. One is the AC unit for wings and tail. This is where I was always under the impression that the AC shined...when I've tried to clean, wax or work under the wings or tail a regular creeper is way too low, and a stool has you craned over and tweaking your back. For those who don't use Aerocreeper for under the wings, what do you use? Quote
Hank Posted February 29, 2024 Report Posted February 29, 2024 5 hours ago, Marc_B said: For those who don't use Aerocreeper for under the wings, what do you use? I sit on the floor. A folded towel under my butt helps a little, add a cushion and it's better (I keep two in the plane for my vertically challenged wife). Quote
Joseph Long Posted February 29, 2024 Report Posted February 29, 2024 On 2/27/2024 at 6:46 PM, Hank said: I have the gray one from Harbor Freight, works well. Same here. I took a nap on it in the hanger one day waiting for weather to clear. Quote
PT20J Posted February 29, 2024 Report Posted February 29, 2024 I’m thinking this might be a better option. https://www.griotsgarage.com/cadillac-of-creepers/?sku=38912&code=PPCPLG&gad_source=1&gclid=Cj0KCQiA84CvBhCaARIsAMkAvkJmia1oOH-t7asCHQy6y6Ya7_5vD0BREY6F9JI-iX_t_X7lOo_G_MkaAqOjEALw_wcB Quote
Marc_B Posted March 1, 2024 Report Posted March 1, 2024 On 2/29/2024 at 3:51 AM, Hank said: I sit on the floor. That's what I do, and every time it gives me less incentive to do anything under there! That's the part I could see an AC shining, but also the part that most owners would probably spend the least amount of time with. Quote
