Here are a couple of pics of my new panel. I’ve watched this space for years and have been inspired by all of your pics and comments. I hope my experience provides some inspiration to others.
This upgrade is the second phase in what I envision will be a 3 phase project. When I purchased 11Q (1965 C model) 8 years ago it had a “shotgun” panel on the left side and typical engine instruments on the right. Phase 1 was to completely redo the left side into a traditional “6 pack” layout. At that time I put in a Sandia Quattro ADI. Phase 2 brings us to where we are today. Equipment installed:
GI 275
GFC 500 (2 axis)
PMA 8000 (previously installed)
GNS 530W (previously installed)
GTR 225
GTX 330ES (previously installed)
JPI EDM 900
GSB 15
Phase 3 (TBD) replaces the vacuum driven DG (and removal of the vacuum pump) with another GI 275 and installs an upgraded navigator.
I was planning to install a Dynon system but the lack of an autopilot, or even a clear path to one for the short bodies, sent me in another direction.  Once I decided to go with Garmin I went all in. I considered a G3X Touch but the price and the desire to retain some of the “vintage” look drove me towards this solution.  I kept the original yokes for this same reason.  Finally, what you really want to know; Phase 2 was 58 AMUs and took about 4 weeks. Done at a well run shop on the East Coast.
Nice.
Any reason you did not add a second 275 and have an HSI?
A G3X Touch would have been nice, as you could control the transponder and second nav/com from it.  But yes, the incremental cost is fairly high, so I understand that decision.
For the future, if you replace the GNS with a GTN, you can control the transponder from it.
FYI, not criticizing, just musing.
I did very similar upgrades but did the HSI first and then the ADI as phase 2.   The HSI does not disappoint.
My phase 3 is the autopilot and will complete my upgrades unless my older audio panel goes kaput.
5 hours ago, Pinecone said:
Nice.
No worries, I appreciate the input. It was simply a matter of cost.  Everything else I put in was a “must do” during this phase.  The HSI will certainly be a nice addition when I’m ready to do it.
