What is the material in the exterior door handle seal? Does anyone have a source to replace the seal alone, outside of replacing the entire handle with seal?
On 10/20/2023 at 7:46 AM, A64Pilot said:
Use the sponge rubber that’s on the refrigerant lines for a house airconditioner? That stuff seems to last a long time.
I didn’t know there was a seal there.
I’m pretty sure that is neoprene. That would be a good choice.
This is way to much, but the price is right.
https://www.amazon.com/Sponge-Neoprene-Thick-54-Wide/dp/B001FZTO06
Foam rated for outdoor UV protection is all that it would take…
Material
density
dimensions
fire resistant
and best glue to use
may make a call to Lasar a worthwhile endeavor…
Automotive foams often have similar qualities…
How much does the Mooney specific foam go for lately?
Also be looking for a seal inside the door…
a split rubber sheet that allows the mechanism to slide may be hiding in there as well…
PP thoughts only not a mechanic…
BTW, it's not a seal. It's just a cushion. It's not critical and I haven't bothered to replace mine, though the handle is a bit recessed without it. You can replace it with any type of foam cut to fit.
@PT20J That certainly makes more sense as it certainly doesn't seem to be sealing much, but having the handle in the right place makes it easier to lock/turn the key.
