hammdo Posted July 19, 2023 Report Posted July 19, 2023 And there is a difference in the original SWTA 201 windshield vs the factory/Lasar 201. The Lasar 201 is bit further forward and doesn’t have as much room for the inspection panels. Something to keep in mind when you fit the cover - may need to tweak things for the SWTA cover to fit. I have the SWTA 201 version on my C and just had the windshield replaced. -Don Quote
nevadabandit Posted July 20, 2023 Author Report Posted July 20, 2023 HELP!! Bled the hydraulic system today, rebuilt the Flap Pump (new O rings) Bled the brakes, Left unit cleaned up great and has great brake action, but the right would pump up and then not release. Removed the Right master cylinder, put new O rings in it, found the A-47G-045 Valve assemble O ring dry and cracked! As you know the little O ring is a part of the valve assembly and must be replaced as a unit (see Print attached) Where can we find one of these to purchase??? Nevadabandit on the search!! Quote
MB65E Posted July 20, 2023 Report Posted July 20, 2023 Call Bill Goetschel super helpful guy. He tooled up to rebuild these. There is a beveled washer that cracks. He has a little hustle on eBay, but just call him directly. +1 (507) 581-9761 carolannegoetschel@yahoo.com -Matt Quote
nevadabandit Posted July 20, 2023 Author Report Posted July 20, 2023 2 hours ago, MB65E said: Call Bill Goetschel super helpful guy. He tooled up to rebuild these. There is a beveled washer that cracks. He has a little hustle on eBay, but just call him directly. +1 (507) 581-9761 carolannegoetschel@yahoo.com -Matt Thank you Matt, Call Bill and were all set up to send both units to him! I also found that Avstat Aviation in Van Nuys CA has the service kits, they are #VV15625 for about $80 Thanks again for the tip! 1 Quote
