davesly Posted May 24, 2023 Report Posted May 24, 2023 Thanks everyone for the help so far in finding parts. I thought I would share my new Mooney Resurrection project. The pics on this post show the plane, about 10 years ago before, and after the hangar accident as well as how I purchased it last month (It came with the cowling and inspection panels). Thanks to the help from people on this board, I now have an engine, prop and baffles. I'll be posting pics of the restoration in this new topic. My goal is to keep the interior and exterior original, but have a nearly zero time mechanicals and a full Dynon glass Avionics system with GTN 650 or 750 GPS. 3
davesly Posted May 24, 2023 Author Report Posted May 24, 2023 Here is a pic of the zero time overhauled IO-360-A1A with 100 hour slick mags (4345/4370 with SlickStart). Mechanically, I'll be installing the following: new Sky-Tec Starter (NL) new Power-plane AL12-P70 Amp Alternator PCU-5000 Governor ATH1 new mechanical Fuel pump it had a new Electric boost pump installed at the accident annual ditching the vacuum pump new Powerflow exhaust system 120 hour SPOH (100 hr Eddy-Current required AD prop) to start with New Mixture and Throttle cables (mine are a bit sticky) New Fuel/Oil Hoses Rebuilt Oil cooler Blasted and powder coated engine mount with AD gussets welded in New Lord engine mounts and engine mount-firewall hardware 4
Denis Mexted Posted May 24, 2023 Report Posted May 24, 2023 Best of luck davesly. I'm about half way through my own F model reno. VH-KWA. 1
davesly Posted May 26, 2023 Author Report Posted May 26, 2023 I decided to go with the Garwin 34-828-014 governor instead of the PCU-5000. After feedback from some members, I found that Mooney used two types of governors based on where the prop cable comes out of the firewall. Mine comes out on the left (pilot) side and mounts to a triangular aluminum bracket (see picture). Other planes (prior to 1969) used a piece of 90-angle-aluminum extrusion mounted up and to the right for the cable coming off the right side of the firewall. It appears that the default configuration of the PCU-5000 is to replace this right-hand style of Hartzell Governor and thus the rotation and indexing of the ATH-1 requires reconfiguration for my mount type. In order to make things simpler, I opted to just go with an overhauled Garwin $1,550 which is also about 1/2 price. Additional research shows the 34-828-014 being used on both 0-360 and IO-360 for all Mooney models in 1969 (probably other years also).
davesly Posted November 5 Author Report Posted November 5 The new engine is in, prop and exhaust installed. Just hooking up the details. We have a new mechanic at Freeport, IL now who is familiar with Mooneys. Progress moving much faster now. 5
