Vetterun Posted January 28, 2023 Report Posted January 28, 2023 1986 252 TSE - #2 Alt Field breaker keeps opening when I increase engine rpm. Intermittent problem. Sometimes the red alert light comes on fully, sometimes dimly. Can a circuit breaker partially wear out and become "weak"? Any thoughts?
PT20J Posted January 28, 2023 Report Posted January 28, 2023 What’s the POH say? Mine says this. Over voltage relay is in the voltage regulator. Check all the wiring first..
LANCECASPER Posted January 29, 2023 Report Posted January 29, 2023 2 hours ago, Vetterun said: 1986 252 TSE - #2 Alt Field breaker keeps opening when I increase engine rpm. Intermittent problem. Sometimes the red alert light comes on fully, sometimes dimly. Can a circuit breaker partially wear out and become "weak"? Any thoughts? When you say it keeps popping, are you continuing to re-set it in the air?
Marc_B Posted January 29, 2023 Report Posted January 29, 2023 If you have an engine monitor you can download the data and see what your voltages have been running. Might be easier to see what's been happening after the fact with some recent flight data.
Marc_B Posted January 29, 2023 Report Posted January 29, 2023 15 hours ago, AIREMATT said: Voltage regulator wearing out? and if it turns out to be this, Don Maxwell can service the VRs unless it's labeled IAI (International Avionics Inc.); I think Consolidated Aircraft Supply can also service them. (edit: if it's labeled IAI, then send it off to International Avionics, Inc in Texas and they can service.) 1
Vetterun Posted January 30, 2023 Author Report Posted January 30, 2023 thanks for the ideas. I was trying to re-set it in the air, but not using the full process as described in the POH. I'll do that today on the ground. The alternator has been sent out for testing and returned fine. Wiring pretty thoroughly checked. Next up is the regulator, then the circuit breaker. Will update on progress. Thanks again for the suggestions. The Systems section of thePOH, which I hadn't checked, was most informative with excellent diagrams. DOH on me!
Vetterun Posted January 30, 2023 Author Report Posted January 30, 2023 On 1/28/2023 at 7:55 PM, LANCECASPER said: When you say it keeps popping, are you continuing to re-set it in the air? Yes, but only by turning the alternator rocker switch off then resetting the circuit breaker. Still, probably not wise while in the air. The full regulator reset involves turning off the communications equipment switch, then the master switch off and back on. I'll do that on the ground today.
LANCECASPER Posted January 30, 2023 Report Posted January 30, 2023 3 minutes ago, Vetterun said: Yes, but only by turning the alternator rocker switch off then resetting the circuit breaker. Still, probably not wise while in the air. The full regulator reset involves turning off the communications equipment switch, then the master switch off and back on. I'll do that on the ground today. Yeah the natural urge is to re-set since we have the hope that it will just fix itself. But since the breakers are there to protect the wiring - the last thing anyone wants to deal with is an in-flight fire. Good job getting it back on the ground safely, where it's much easier to figure these things out. 1
