Yooper Rocketman Posted September 17, 2022 Report Posted September 17, 2022 My intercom died and I will be putting in a complete new panel next summer with a new audio panel/intercom. Looking to just replace this old dinosaur until then. Tom
jcovington Posted September 17, 2022 Report Posted September 17, 2022 @Yooper Rocketman I have one that I pulled out several years ago to put in a PSE intercom. It was working fine then. It won't be hard to talk me out of it. The unit you have in your hand is the control head. There is another box that is actually the intercom. The head unit comes apart if you want to try to repair it. There is a header behind the board that holds the switches. On mine the solder was poorly done and I had to resolder it a few years before I replaced it. Jim
ilovecornfields Posted September 17, 2022 Report Posted September 17, 2022 I can’t help you with the intercom, but where I come from DRE stands for “digital rectal exam.” If you want, I’ll even use two fingers so I can give you a second opinion. 1 2
201Steve Posted September 17, 2022 Report Posted September 17, 2022 You can typically find Dre in South Central LA, the Dr., that is. While we are making Dre jokes.
LANCECASPER Posted September 18, 2022 Report Posted September 18, 2022 6 hours ago, ilovecornfields said: I can’t help you with the intercom, but where I come from DRE stands for “digital rectal exam.” If you want, I’ll even use two fingers so I can give you a second opinion. In Aviation don't they call that an Annual Inspection? 1
ilovecornfields Posted September 18, 2022 Report Posted September 18, 2022 1 hour ago, LANCECASPER said: In Aviation don't they call that an Annual Inspection? I certainly had an annual that felt like I was getting a DRE. 1
LANCECASPER Posted September 18, 2022 Report Posted September 18, 2022 6 minutes ago, ilovecornfields said: I certainly had an annual that felt like I was getting a DRE. 1
Yooper Rocketman Posted September 18, 2022 Author Report Posted September 18, 2022 19 hours ago, jcovington said: @Yooper Rocketman I have one that I pulled out several years ago to put in a PSE intercom. It was working fine then. It won't be hard to talk me out of it. The unit you have in your hand is the control head. There is another box that is actually the intercom. The head unit comes apart if you want to try to repair it. There is a header behind the board that holds the switches. On mine the solder was poorly done and I had to resolder it a few years before I replaced it. Jim Jim, Yes, I'm aware of the control module as well (already replaced both the module and the control display with an unkownn "possible working" unit. The module was a REAL BITCH on my Rocket Conversion as there is no access to the F/W. If you have that set up and are willing to part with it, let me know what I can do to get that done. Mine failed with 3 other much more expensive avionics (Garmin 345, KX-155, and HSI) from someone arcing a hot wire across my almost new Garmin 345 Transponder. I won't discuss what the rest of the stuff cost. Sure made the engine install, putting 16 pounds of crap in a 3 pound container (Rocket engine in a 231 airframe), without a single serious squawk, look easy. Let me know. Thanks Tom
Yooper Rocketman Posted September 18, 2022 Author Report Posted September 18, 2022 18 hours ago, ilovecornfields said: I can’t help you with the intercom, but where I come from DRE stands for “digital rectal exam.” If you want, I’ll even use two fingers so I can give you a second opinion. Been there, done that. Would rather not know the guy doing the procedure though 1
jcovington Posted September 18, 2022 Report Posted September 18, 2022 2 hours ago, Yooper Rocketman said: Jim, Yes, I'm aware of the control module as well (already replaced both the module and the control display with an unkownn "possible working" unit. The module was a REAL BITCH on my Rocket Conversion as there is no access to the F/W. If you have that set up and are willing to part with it, let me know what I can do to get that done. Mine failed with 3 other much more expensive avionics (Garmin 345, KX-155, and HSI) from someone arcing a hot wire across my almost new Garmin 345 Transponder. I won't discuss what the rest of the stuff cost. Sure made the engine install, putting 16 pounds of crap in a 3 pound container (Rocket engine in a 231 airframe), without a single serious squawk, look easy. Let me know. Thanks Tom Tom The intercom is yours. The only problem is that I am out or town this week and it is in my hangar at home. I can ship it to you when I get back on Sunday. PM me your address if that will work. Sorry about the shorted wire. You are right the intercom won't be worth repairing. Jim 1
Yooper Rocketman Posted September 18, 2022 Author Report Posted September 18, 2022 (edited) Jim, ok, will PM you Thanks, Tom Edited September 18, 2022 by Yooper Rocketman Removed TMI
Yooper Rocketman Posted September 18, 2022 Author Report Posted September 18, 2022 Crap, was using my iPhone and thought I was messaging.
