Hank Posted August 4, 2022 Report Posted August 4, 2022 My wife's ipad started flashing befween black screen and white screen with black apple. Doesn't stop until the battery runs down; once charged, it starts again. Geek Squad says its dead. Any other opinions / repairs? If not, I'm in the market but am not an apple follower. What's a good place to shop? What's a fair price these days? Got one you no longer need? Quote
Robert Hicks Posted August 4, 2022 Report Posted August 4, 2022 Which version iPad is it? Apple doesn’t really let their retailers do discounts except for Costco from what I’ve seen. The newest iPad mini 6 is around 600$ I think. Quote
anthonydesmet Posted August 4, 2022 Report Posted August 4, 2022 Think the latest version of iPad mini is the 5th generation. 4th and 5 gen have a slightly different size so if you were flying with your old one on your yoke mount the newer version might not fit depending on RAM mount. price will depend on memory size and whether you go Wi-Fi only or wifi plus cellular service. I think it’s $500 to $650 respectively for the lower memory option. I have an older 2nd gen mini but it might frustrate you as the current apple OS updates don’t really run optimally on older iPad and iPhone versions……that’s how they get ya……my grandpa would say…… Quote
LANCECASPER Posted August 4, 2022 Report Posted August 4, 2022 17 minutes ago, anthonydesmet said: Think the latest version of iPad mini is the 5th generation. 4th and 5 gen have a slightly different size so if you were flying with your old one on your yoke mount the newer version might not fit depending on RAM mount. price will depend on memory size and whether you go Wi-Fi only or wifi plus cellular service. I think it’s $500 to $650 respectively for the lower memory option. I have an older 2nd gen mini but it might frustrate you as the current apple OS updates don’t really run optimally on older iPad and iPhone versions……that’s how they get ya……my grandpa would say…… The latest is the 6th Good place to go is https://www.apple.com/shop/refurbished 1 Quote
Pinecone Posted August 4, 2022 Report Posted August 4, 2022 Check with an Apple store. I cracked the screen on my new iPad Gen 9, and they swapped it for a replacement for $250. Quote
ArtVandelay Posted August 4, 2022 Report Posted August 4, 2022 Could be one of the buttons is locked in “push” mode, try spraying with electronic cleaner. But chances are even if that’s the problem, the Idevices are so tightly made (and water resistant) the cleaner won’t be able to penetrate. You can just buy a generic iPad (no cellular, non pro) for $330, and it will run any EFB just fine. Quote
Ned Gravel Posted August 4, 2022 Report Posted August 4, 2022 Hank: Don’t know if you folks in the US have an equivalent, but I just got my backup iPad (Gen 4 mini) back from Ubreakifix for not being able to connect to any wifi. Two days and $120.00 Cdn later it is back. They have replaced screens and batteries for me in iPhones and iPads over the years. They know their stuff. Never had any issues with their work. Quote
Fly Boomer Posted August 4, 2022 Report Posted August 4, 2022 12 hours ago, anthonydesmet said: 4th and 5 gen have a slightly different size If we are talking about the Mini, gen 4 and gen 5 are identical in appearance and dimension. I have both in front of me. Quote
Fly Boomer Posted August 4, 2022 Report Posted August 4, 2022 5 minutes ago, Ned Gravel said: got my backup iPad (Gen 4 mini) back from Ubreakifix for not being able to connect to any wifi. Two days and $120.00 Cdn later it is back. They have replaced screens and batteries for me in iPhones and iPads over the years. They know their stuff. Never had any issues with their work. As with aircraft mechanics, I think it depends more on the person doing the work than the name of the business. UbreakIfix fixed the problem I was having with my Samsung phone, but destroyed the internal connections to the auxiliary memory card. Quote
Fly Boomer Posted August 4, 2022 Report Posted August 4, 2022 12 hours ago, Hank said: My wife's ipad started flashing befween black screen and white screen Gen 5 Wi-Fi only, 64 GB https://www.apple.com/shop/product/FUQY2LL/A/Refurbished-iPad-mini-5-Wi-Fi-64GB-Gold Quote
N201MKTurbo Posted August 4, 2022 Report Posted August 4, 2022 You can buy last generation IPads on EBay for 1/3 of new price. I have changed quite a few screens and batteries. They are very cheap. The skills are not over the top. My only advice is to clean off all the chips and debris from the old screen before sticking on the new one. Looking at the surface with a microscope is a good idea. With your problem, you need to replace the CPU board. You have to replace the screen because it is almost impossible to get one off without breaking it. You might as well replace the battery while you are at it. In other words the only part you will be able to salvage is the case. And a few peripherals like the camera and radio. Listen to Geek Squad and buy a new(er) one. Quote
Unit74 Posted August 6, 2022 Report Posted August 6, 2022 Are you a veteran or have one in the family who will buy for you? Apple will give you a discount if so. https://www.apple.com/shop/browse/home/veterans_military Quote
