woodman86 Posted May 3, 2022 Report Posted May 3, 2022 So I’m looking for information on a particular prop and do I need an eddy current every year or visual every year I’m not clear on this my prop model is a HC – C2YK - IBF/F 7666A-2 Serial number CH25337 Quote
Hank Posted May 3, 2022 Report Posted May 3, 2022 @Cody Stallings is our prop guru. He'll know. The Hartzell 3-blade on my C doesn't need any of that stuff. I thought it was only a particular McCauley hub, but I'm not sure. 1 Quote
Igor_U Posted May 3, 2022 Report Posted May 3, 2022 1 hour ago, woodman86 said: So I’m looking for information on a particular prop and do I need an eddy current every year or visual every year I’m not clear on this my prop model is a HC – C2YK - IBF/F 7666A-2 Serial number CH25337 I believe you do need a eddy current inspection as your S/n does not have a suffix "B". You should be able to find an Ad online and more details in it. Quote
Guest Posted May 3, 2022 Report Posted May 3, 2022 This is the AD in question. ECI check every 100 hours. https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgad.nsf/0/6b6b68153b98376a8625765c005290eb/$FILE/2009-22-03.pdf Clarence Quote
Cody Stallings Posted May 4, 2022 Report Posted May 4, 2022 12 hours ago, woodman86 said: So I’m looking for information on a particular prop and do I need an eddy current every year or visual every year I’m not clear on this my prop model is a HC – C2YK - IBF/F 7666A-2 Serial number CH25337 Actually your propeller hub is Non-Suffix. Its actually supposed to have a one-time tear down inspection performance. At that time the Hub Serial number will have an E stamped. After that the 100 ECI inspections start. 1 Quote
