rbp Posted February 24, 2022 Report Posted February 24, 2022 On 2/22/2022 at 11:01 PM, donkaye said: I wouldn't want to be the insurance company that insures that airplane unless the annual insurance fee is the cost of the airplane. An Acclaim was put on the line at Palo Alto a number of years ago. 3 prop strikes later the plane went into default and was repossessed. Who would ever want it after all those prop strikes? I brought it back from Kerrville before it went on the line. It looked good then. A couple of years later it looked like your typical rental plane---garbage. The only beneficiaries may be the renters who don't give a cr*p about the plane, want to go fast, and will destroy the engine in short order. On top of everything else, with the altitude in Denver, landings will be at least 10% faster than at sea level and may expedite the first prop strike. It's a fools errand to put any long body Mooney on the line, expecting to make money while cutting their own flying expenses. They are in for a real eye opening experience. After 30 years' experience with the Bravo, there is so much more I could say, but it would likely just fall on deaf ears. we have our T-6G on the line at Advantage Aviation in Palo Alto. There are only 2 (non-partner) pilots allowed to act as PIC, and they also happen to be instructors who can . https://www.advantage-aviation.com/aircraft/n555q/ https://www.bayareawarbirds.com/ Quote
carusoam Posted February 25, 2022 Report Posted February 25, 2022 10 hours ago, rbp said: we have our T-6G on the line at Advantage Aviation in Palo Alto. There are only 2 (non-partner) pilots allowed to act as PIC, and they also happen to be instructors who can . https://www.advantage-aviation.com/aircraft/n555q/ https://www.bayareawarbirds.com/ rbp, What type of commitment is required to get a skilled pilot up to speed with flying the T-6G as PIC? Number of hours for Transition Training would be interesting… Looks like an expensive method to get a tail wheel rating…. Best regards, -a- 1 Quote
rbp Posted February 25, 2022 Report Posted February 25, 2022 8 hours ago, carusoam said: rbp, What type of commitment is required to get a skilled pilot up to speed with flying the T-6G as PIC? Number of hours for Transition Training would be interesting… Looks like an expensive method to get a tail wheel rating…. Best regards, -a- its only available for dual with one of the approved instructors. no TW endorsement required. I did my TW in the mighty citabria! if someone wants to come in as a partner, they have to have unanimous approval and be qualified, which means not only insurance, but have a lot of high-performance time and lots of TW time. its a handfull 1 Quote
alextstone Posted February 27, 2022 Report Posted February 27, 2022 On 1/3/2022 at 2:38 PM, rbp said: it was marketed as a 220KTAS airplane at FL250. i don't remember the engine settings, but probably BTTW. EDIT: I mean 220KTAS (not 200). still don't know what power settings In my bravo, I cruise at 29"MP and 2400 RPM - 100 degrees ROP which works out to 19.7 GPH. This is also 75% power from the engine. At those settings, I can expect 165 - 170 KTAS kts below 4000 Then, increasing 5 knots every additional 3000 feet, give or take So at 7000 = 175, 10k feet = 180 kts, 13K feet = 185 kts, 16K feet = 190, 19k feet - 195 kts, 22k feet = 200kts, 24k feet = 205kts. My model has TKS As you can see, my airplane maxes out at 205KTAS. The only way to "possibly" see 220 knots would be increase the MP to 34 (my guess). The engine and exhaust will probably get too hot to sustain that for a lenghy period of time k 2 Quote
Jerry 5TJ Posted February 27, 2022 Report Posted February 27, 2022 https://www.apaflyers.com “Under $500 per hour wet!” 1 Quote
rbp Posted February 27, 2022 Report Posted February 27, 2022 11 hours ago, alextstone said: At those settings, I can expect 165 - 170 KTAS kts below 4000 Then, increasing 5 knots every additional 3000 feet, give or take So at 7000 = 175, 10k feet = 180 kts, 13K feet = 185 kts, 16K feet = 190, 19k feet - 195 kts, 22k feet = 200kts, 24k feet = 205kts. are these measured numbers? or extrapolated? Quote
alextstone Posted February 28, 2022 Report Posted February 28, 2022 are these measured numbers? or extrapolated?Let's just say they are midrange averages. Weight, temperature etc create variations. Your results may varySent from my Pixel 5a using Tapatalk Quote
Jetpilot86 Posted February 13, 2024 Report Posted February 13, 2024 I actually did the insurance checkout for my Bravo in this one.... They are pretty picky about it, not sure if it's in general or because of stuff that happened between the start of this thread and when I checked out. As I recall, not a lot are checked out on it because the insurance requirements are pretty stiff... Nice bird. Quote
xcrmckenna Posted February 13, 2024 Report Posted February 13, 2024 I actually did the insurance checkout for my Bravo in this one.... They are pretty picky about it, not sure if it's in general or because of stuff that happened between the start of this thread and when I checked out. As I recall, not a lot are checked out on it because the insurance requirements are pretty stiff... Nice bird.I have emailed them twice to get details on checkout. Even explained I only wanted dual instruction for insurance checkout for future Bravo purchase with no response. Sent from my iPhone using Tapatalk Quote
PilotX Posted February 13, 2024 Author Report Posted February 13, 2024 7 hours ago, xcrmckenna said: I have emailed them twice to get details on checkout. Even explained I only wanted dual instruction for insurance checkout for future Bravo purchase with no response. Sent from my iPhone using Tapatalk What is the requirement for an insurance checkout these days? I know my open pilot requires 750/Instrument/25M&M. Quote
toto Posted February 14, 2024 Report Posted February 14, 2024 1 hour ago, PilotX said: What is the requirement for an insurance checkout these days? I know my open pilot requires 750/Instrument/25M&M. Your post made me wonder what portion of a premium cost is going to the open pilot clause. Zero other pilots have flown my Mooney since the day I bought it, and I don’t have any intention of changing that track record anytime soon Quote
PilotX Posted February 14, 2024 Author Report Posted February 14, 2024 2 hours ago, toto said: Your post made me wonder what portion of a premium cost is going to the open pilot clause. Zero other pilots have flown my Mooney since the day I bought it, and I don’t have any intention of changing that track record anytime soon Unknown. I have seen quotes vary wildly on my plane. PPL it tripled, 10000+ ATP the quote was for a few hundred extra. Quote
xcrmckenna Posted February 19, 2024 Report Posted February 19, 2024 What is the requirement for an insurance checkout these days? I know my open pilot requires 750/Instrument/25M&M. Have no idea what the open pilot requirements are, guessing checkout on your own policy is 5 or 10 for solo maybe 20-25 for passengers. In 2016 it was like 5 for my 201 and maybe 10 for passengers. I got checked out in a 201 awhile before I bought mine and had about 20hrs total, I’m pretty sure that put me in a lower insurance bracket but might not be the case now. But the biggest benefit to being checked out in the plane prior to purchase I was able to fly it home to Oregon from Texas and didn’t need a CFI or spend a week or two with an instructor before I could fly home, or have someone fly it home for me. Sent from my iPhone using Tapatalk Quote
Fritz1 Posted February 19, 2024 Report Posted February 19, 2024 For the reasons already stated above a rental Bravo is unlikely to be found. Simplest way to get Bravo time is go Bravo shopping and fly with the owners. Jimmy Garrison has a couple for sale and also has a personal Bravo. Once a candidate aircraft has been identified make a qualified instructor part of your pre-purchase team. Once the aircraft is purchased do the shake down and ferry flights with that instructor. 25h in make and model will have accumulated when you are done pre-purchasing, shaking down and ferrying. Quote
xcrmckenna Posted February 20, 2024 Report Posted February 20, 2024 For the reasons already stated above a rental Bravo is unlikely to be found. Simplest way to get Bravo time is go Bravo shopping and fly with the owners. Jimmy Garrison has a couple for sale and also has a personal Bravo. Once a candidate aircraft has been identified make a qualified instructor part of your pre-purchase team. Once the aircraft is purchased do the shake down and ferry flights with that instructor. 25h in make and model will have accumulated when you are done pre-purchasing, shaking down and ferrying. Flying with the owner isn’t getting you check out time. And most sellers I’ve worked with isn’t spending hours with you up in the air as you shake down their airplane hoping you will buy it. I looked at 16 201’s and got notes from 32, before I found one to buy. Candidates take time to vet. When I purchase a bravo I want to be ready to fly it home and not have to coordinate with multiple people to get to that point. I’m good with planning a trip to the Denver area to get checked out in this Bravo discussed in this thread. Each their own. Sent from my iPhone using Tapatalk Quote
Fritz1 Posted February 20, 2024 Report Posted February 20, 2024 got it, call Jimmy Garrison at Gmax American and Richard Simile at Thunderbird, they are in the biz of selling airplanes and have a bunch of them sitting around, you look like a guy who wants to buy one, getting you checked out should be a marketing effort for them, at $500/h one of them will figure this out and you might learn a thing or two from them that helps you find the right airplane, I keep fingers crossed! Quote
Jetpilot86 Posted March 3, 2024 Report Posted March 3, 2024 On 2/20/2024 at 9:42 AM, xcrmckenna said: Flying with the owner isn’t getting you check out time. And most sellers I’ve worked with isn’t spending hours with you up in the air as you shake down their airplane hoping you will buy it. I looked at 16 201’s and got notes from 32, before I found one to buy. Candidates take time to vet. When I purchase a bravo I want to be ready to fly it home and not have to coordinate with multiple people to get to that point. I’m good with planning a trip to the Denver area to get checked out in this Bravo discussed in this thread. Each their own. Sent from my iPhone using Tapatalk The Mooney at APA is currently not available due to some sort of contract issue with the owner. No idea when, or if, it’s going to be available again. Quote
PilotX Posted May 4, 2024 Author Report Posted May 4, 2024 Up for sale...like buying a used rental car. https://denver.craigslist.org/avo/d/littleton-2005-mooney-m20m-bravo/7743082524.html Quote
Fritz1 Posted May 4, 2024 Report Posted May 4, 2024 Good looking bird, turbo Mooney just not suitable for rental ops Quote
wombat Posted May 5, 2024 Report Posted May 5, 2024 $350k with the engine at 1,300 hours and it doesn't even have TKS? It's not really for sale, it's "My wife said I had to sell it." 2 Quote
kris_adams Posted May 7, 2024 Report Posted May 7, 2024 craigslist isn't exactly where I would list my plane to sell. Quote
Jetpilot86 Posted May 13, 2024 Report Posted May 13, 2024 On 5/4/2024 at 3:33 PM, PilotX said: Up for sale...like buying a used rental car. https://denver.craigslist.org/avo/d/littleton-2005-mooney-m20m-bravo/7743082524.html This is the one I did my insurance checkout in at APA. Nice bird. Prop Deice but no TKS as mentioned. Clean airplane. Quote
