Gubni Posted May 2, 2021 Report Posted May 2, 2021 I'd like to keep the discussion about the prop only please. One blade has a bend. See attached picture. Should I buy a new prop, refurbished prop, or have this one fixed? What company should I ask for help? Quote
kerry Posted May 2, 2021 Report Posted May 2, 2021 What blades do you have? Some are hard to come by. Quote
Gubni Posted May 2, 2021 Author Report Posted May 2, 2021 (edited) 4 minutes ago, kerry said: What blades do you have? Some are hard to come by. It's a Mccauley 2 blade on a M20K 252. I believe the model is C216 Edited May 2, 2021 by Gubni Quote
Rwsavory Posted May 2, 2021 Report Posted May 2, 2021 Might be repairable. Cody Stallings is the guy to talk to. @Cody Stallings 2 Quote
Guest Posted May 2, 2021 Report Posted May 2, 2021 From the type certificate, you can not reduce the blade length, or prop diameter. Quote
Bartman Posted May 2, 2021 Report Posted May 2, 2021 I wouldn’t worry about that. I’ll buff right out with some polishing compound. Quote
MIm20c Posted May 2, 2021 Report Posted May 2, 2021 1 minute ago, Bartman said: I wouldn’t worry about that. I’ll buff right out with some polishing compound. Or just even it out by taking sheet metal pliers to the other blade. Kick it old school with the Q-tip design. Being serious best option would be to buy one new blade and iran or overhaul the prop. Not many people upgrade from that prop, new might be your only option. Quote
Hank Posted May 2, 2021 Report Posted May 2, 2021 Can a blade be hit hard enough to bend without requiring engine teardown & inspection? Quote
MikeOH Posted May 2, 2021 Report Posted May 2, 2021 Just now, Hank said: Can a blade be hit hard enough to bend without requiring engine teardown & inspection? 1 hour ago, Gubni said: I'd like to keep the discussion about the prop only please. Quote
Cody Stallings Posted May 2, 2021 Report Posted May 2, 2021 57 minutes ago, Gubni said: It's a Mccauley 2 blade on a M20K 252. I believe the model is C216 That should be the -16 McCauley blade. However, that blade isn’t looking good without Reduction in diameter. I know where a set of those blades are at Overhauled with no Mooney to call home. Quote
Gubni Posted May 2, 2021 Author Report Posted May 2, 2021 6 hours ago, Cody Stallings said: That should be the -16 McCauley blade. However, that blade isn’t looking good without Reduction in diameter. I know where a set of those blades are at Overhauled with no Mooney to call home. Please send me a message with details. Quote
Guest Posted May 2, 2021 Report Posted May 2, 2021 The same blade set is used in the McCauley propeller on a J model which is allowed to be shortened, so your blade may have some remaining value. Clarence Quote
Gubni Posted May 2, 2021 Author Report Posted May 2, 2021 6 minutes ago, M20Doc said: The same blade set is used in the McCauley propeller on a J model which is allowed to be shortened, so your blade may have some remaining value. Clarence That's awesome! Maybe a dealer can give me trade-in. Quote
Guest Posted May 2, 2021 Report Posted May 2, 2021 2 minutes ago, Gubni said: That's awesome! Maybe a dealer can give me trade-in. As long as it can be saved at 73” for a J, it should have some value. Clarence Quote
bradp Posted May 2, 2021 Report Posted May 2, 2021 10 hours ago, Gubni said: I'd like to keep the discussion about the prop only please. One blade has a bend. See attached picture. Should I buy a new prop, refurbished prop, or have this one fixed? What company should I ask for help? Is this the 231 that you found that needed an engine and a prop project? Quote
Gubni Posted May 3, 2021 Author Report Posted May 3, 2021 13 hours ago, bradp said: Is this the 231 that you found that needed an engine and a prop project? Yes, I will probably go with Western Skyways for the engine. I just don't know who to go with for the prop. Quote
carusoam Posted May 3, 2021 Report Posted May 3, 2021 23 hours ago, Cody Stallings said: I know where a set of those blades are at Overhauled with no Mooney to call home. Give this a second look... MSer’s prop guy... Known to have and share all the details required for good prop decisions... Owns an M20K Rocket... When it comes to mangled pieces of prop... I went with something completely different... I couldn’t tell where the damage ended, and the good prop began... and if a metallurgist would be needed... MS has a metallurgist... There are such great forces on the prop... and the slightest imbalance can have disastrous results... as in losing parts of the prop can be really bad. Make sure you get the right shape for the airfoil... the whole length of the blades... People dynamically balance their props for the near perfect balance... They dress out any bumps and nicks for near perfect strength... See if there is a way to let these blades go... to somebody with much shorter blade requirements... Pp thoughts only, not a mechanic... Best regards, -a- 2 Quote
bradp Posted May 3, 2021 Report Posted May 3, 2021 19 minutes ago, Gubni said: Yes, I will probably go with Western Skyways for the engine. I just don't know who to go with for the prop. If shipping weren’t an issue I’d sent to Cody in a heartbeat. He’s such a an honest valuable resource here on Mooneyspace and knows Mooney’s. 2 Quote
Gubni Posted May 3, 2021 Author Report Posted May 3, 2021 (edited) 1 minute ago, bradp said: If shipping weren’t an issue I’d sent to Cody in a heartbeat. He’s such a an honest valuable resource here on Mooneyspace and knows Mooney’s. I am waiting on Cody's reply. Edited May 3, 2021 by Gubni 1 Quote
bradp Posted May 3, 2021 Report Posted May 3, 2021 Just now, Gubni said: Is Cody part of Western Skyways or a prop guy? This is why I wanted to avoid engine discussion. Gotcha. Cody Stallings @Cody Stallings is the prop guy. He’s in AR. https://www.stallingsaircraftpropeller.com/contact 2 Quote
Cody Stallings Posted May 3, 2021 Report Posted May 3, 2021 17 hours ago, Gubni said: Please send me a message with details. Give me a shout tomorrow an we can get a game plan together. I have some propellers to deliver local in the am, but I should be back turning wrenches after lunch. 870-208-8882 2 Quote
