Greg Ellis Posted April 23, 2021 Report Posted April 23, 2021 11 hours ago, PT20J said: Why do screws come loose? Vibration coupled with insufficient torque. How can you get insufficient torque? Give the screws a twist every so often. The gasket will compress a little more each time until eventually it looses resiliency. Same thing with hose clamps. Sometimes it is best to leave well enough alone. Skip . I know some will have this on immediate mental recall....so what is the proper torque for Lycoming Rocker Box screws? Quote
N201MKTurbo Posted April 23, 2021 Report Posted April 23, 2021 34 minutes ago, 0TreeLemur said: You're saying that instead of a giving MS participants easy access to non-controversial information, let's make them hunt for it or start a new thread. I don't get it. I can see that. Quote
PT20J Posted April 23, 2021 Report Posted April 23, 2021 1 hour ago, Greg Ellis said: I know some will have this on immediate mental recall....so what is the proper torque for Lycoming Rocker Box screws? 1 Quote
Greg Ellis Posted April 23, 2021 Report Posted April 23, 2021 13 minutes ago, PT20J said: Thank you. Quote
N201MKTurbo Posted April 23, 2021 Report Posted April 23, 2021 2 hours ago, Greg Ellis said: I know some will have this on immediate mental recall....so what is the proper torque for Lycoming Rocker Box screws? As tight as you can get it with an oily plastic screwdriver. 2 Quote
RLCarter Posted April 23, 2021 Report Posted April 23, 2021 44 minutes ago, N201MKTurbo said: As tight as you can get it with an oily plastic screwdriver. Are we talking white knuckle or break wind tight? Quote
N201MKTurbo Posted April 23, 2021 Report Posted April 23, 2021 15 minutes ago, RLCarter said: Are we talking white knuckle or break wind tight? Just till it stops making the grindy sound. 1 Quote
MikeOH Posted April 24, 2021 Report Posted April 24, 2021 On 4/23/2021 at 8:16 AM, PT20J said: Hmm, I've never had a problem with rocker box leaks in over three years of ownership, but I now think I know why others do....35 in-lbs is just under 3 ft-lbs, which is NOT much! I strongly suspect most are waaay overtightened and the cover/gasket distorts and a leak ensues. Followed by MORE tightening to 'stop' the leak. Quote
MikeOH Posted April 25, 2021 Report Posted April 25, 2021 7 minutes ago, GEE-BEE said: Silicone with fiberglass 25/27 inch Pounds The key is fiberglass it’s three times the cost of non reinforced silicone. GB @GEE-BEE I have been very happy with your baffle kit I bought three years ago. Part of what you sent was a set of blue silicone rocker-box gaskets...which I've not yet needed to install! Would they be with the fiberglass? (Not sure you've changed materials since then) 1 Quote
