xcrmckenna Posted September 8, 2020 Report Posted September 8, 2020 Finally found a picture! Hey Danb when you coming over to fill up?Sent from my iPad using Tapatalk Pro Question on procedure on filling up a smaller bottle. I’ve had my portable bottle filled up at FBO’s over the years but I think it’s time to get a set up like yours. Do you just hook the small tank up and open up the bottles and let the pressure neutralize? I know my small tank will get warm and holds the pressure longer we leave it hooked up and cools down. Anything I want to make sure I don’t do, other than the grease and fire concern?Sent from my iPhone using Tapatalk
EricJ Posted September 8, 2020 Report Posted September 8, 2020 (edited) 9 minutes ago, xcrmckenna said: Question on procedure on filling up a smaller bottle. I’ve had my portable bottle filled up at FBO’s over the years but I think it’s time to get a set up like yours. Do you just hook the small tank up and open up the bottles and let the pressure neutralize? I know my small tank will get warm and holds the pressure longer we leave it hooked up and cools down. Anything I want to make sure I don’t do, other than the grease and fire concern? Sent from my iPhone using Tapatalk No, there's a cascade method that lets you cycle out the least full source tank first rather than them all limiting how much pressure you can fill to. The idea is to fill with the lowest pressure (most empty) source cylinder first, then turn it off and open the next (middle) one, and when that has equalized turn it off and open the last (highest pressure) tank and equalize the destination tank to that. That gets you to the pressure of the fullest tank and you can cycle out one source tank when it gets too low to fill with, move the others down the order, and put a fresh tank in the highest pressure spot. Just search on cascade fill system or gas cascade filling or something like that. Edited September 8, 2020 by EricJ 3
xcrmckenna Posted September 8, 2020 Report Posted September 8, 2020 No, there's a cascade method that lets you cycle out the least full source tank first rather than them all limiting how much pressure you can fill to. The idea is to fill with the lowest pressure (most empty) source cylinder first, then turn it off and open the next (middle) one, and when that has equalized turn it off and open the last (highest pressure) tank and equalize the destination tank to that. That gets you to the pressure of the fullest tank and you can cycle out one source tank when it gets too low to fill with, move the others down the order, and put a fresh tank in the highest pressure spot. Just search on cascade fill system or gas cascade filling or something like that. Thanks!Sent from my iPhone using Tapatalk 1
Ross Taylor Posted September 8, 2020 Report Posted September 8, 2020 8 hours ago, Mooney79329 said: Thanks for offering to buy these, Ross. I would like one of the largest size they have. Will be in Flag later this fall. I’ll stop in and grab another. 1
JoeM Posted September 9, 2020 Report Posted September 9, 2020 On 9/7/2020 at 9:27 PM, Ross Taylor said: I’ll stop in and grab another. Please pm me with your contact info so I can come get it.
xcrmckenna Posted September 11, 2020 Report Posted September 11, 2020 Well I put together a very crude transfer station tonight just to make sure I had the capability. And filled my portable tank. Now to get some K bottles and work something up like Marauder. I used welding oxygen and I’m sure that is what I’ve always got at FBO’s but is the consensus ABO is a waste of money? The Norco rep was preaching I purchased ABO, but just wanted to make sure it’s really not needed. If anyone comes through KGCD and needs their O2 filled up hit me up...Sent from my iPhone using Tapatalk 1
gsxrpilot Posted September 11, 2020 Report Posted September 11, 2020 14 hours ago, xcrmckenna said: I used welding oxygen and I’m sure that is what I’ve always got at FBO’s but is the consensus ABO is a waste of money? Oh shit... here we go with another can of worms... That's what I've been filling mine with as well. 1
N201MKTurbo Posted September 30, 2020 Report Posted September 30, 2020 There has been a lot of talk around here about using welding oxygen for breathing. But the other day I needed my torch and found my oxygen was empty. So I went the other way around. 1 2
carusoam Posted September 30, 2020 Report Posted September 30, 2020 Rich, That wins the great humor prize for the evening! Best regards, -a- 1
