r0ckst4r Posted June 21, 2020 Report Posted June 21, 2020 I noticed some blue green fluid under my wing leaking from this panel. The round panel in front of it is the access panel for the landing lights. The fluid is oily and viscous. Does anyone know what this fluid is and what is behind this panel? This is the right (starboard) wing. M20R.
Stnelson903 Posted June 21, 2020 Report Posted June 21, 2020 You have a fuel leak. Sent from my iPhone using Tapatalk
alextstone Posted June 21, 2020 Report Posted June 21, 2020 Yep, that's fuel. I think that panel is the speed brake access panel. The fuel is not coming from there, though...it's seeping back from another location in the wall of one of the fuel bays.... I'm not a mechanic but I play one on the internet... 1 1
EricJ Posted June 21, 2020 Report Posted June 21, 2020 Typical fuel leak. You might be able to take that panel off and see if the stains inside make it obvious exactly where the fuel is getting out. That may not indicate exactly where the patch needs to be done inside the tank, but it'll give you a rough idea. 1
irishpilot Posted June 21, 2020 Report Posted June 21, 2020 fuel all day long and twice on Sunday. it doesn't look too bad now, but it will only get worse with time.Sent from my Pixel 3a using Tapatalk 1
r0ckst4r Posted June 21, 2020 Author Report Posted June 21, 2020 FML. I had a suspicion of fuel because of the color but it was way more oily and viscous than clean 100LL and didn't evaporate which made me think it might be something else. This was the first time I filled the long range tanks ALL the way up so that had something to do with it. I'll see what I can gather from looking in that panel. Thanks for the info as always.
Ross Taylor Posted June 21, 2020 Report Posted June 21, 2020 3 minutes ago, r0ckst4r said: it was way more oily and viscous than clean 100LL That's just because the avgas was the solvent that kept the dye dissolved. Once the solvent (100LL) evaporated away, which happens pretty quickly, the remaining dye is what you're left with there. Good luck with this - we all hope it's an easy patch/fix! 1
StevenL757 Posted June 22, 2020 Report Posted June 22, 2020 37 minutes ago, r0ckst4r said: FML. I had a suspicion of fuel because of the color but it was way more oily and viscous than clean 100LL and didn't evaporate which made me think it might be something else. This was the first time I filled the long range tanks ALL the way up so that had something to do with it. I'll see what I can gather from looking in that panel. Thanks for the info as always. Indeed fuel. Pull that rectangular access panel, remove the screws on top of the wing holding the speed brake in place and gently lower the speed brake. Inspect up inside with a mirror and flashlight to determine where the leak is. If it isn’t apparent, clean the area with mineral spirits and paper towels and monitor to determine where the leak appears to be originating. Steve
Guest Posted June 22, 2020 Report Posted June 22, 2020 53 minutes ago, r0ckst4r said: FML. I had a suspicion of fuel because of the color but it was way more oily and viscous than clean 100LL and didn't evaporate which made me think it might be something else. This was the first time I filled the long range tanks ALL the way up so that had something to do with it. I'll see what I can gather from looking in that panel. Thanks for the info as always. Have your wings been sprayed with any type of anti corrosion spray recently? The green viscous nature suggests Corrosion X. The blue staining is fuel. Clarence
r0ckst4r Posted June 23, 2020 Author Report Posted June 23, 2020 5 hours ago, bradp said: I can’t see the green. Don't tell your FAA medical examiner lol 2
r0ckst4r Posted June 23, 2020 Author Report Posted June 23, 2020 On 6/21/2020 at 8:15 PM, M20Doc said: Have your wings been sprayed with any type of anti corrosion spray recently? The green viscous nature suggests Corrosion X. The blue staining is fuel. Clarence Not unless it was done at the annual but that was in February. I will see if they did anything like that though.
RLCarter Posted June 23, 2020 Report Posted June 23, 2020 9 minutes ago, r0ckst4r said: Not unless it was done at the annual but that was in February. I will see if they did anything like that though. I’ve seen corrosion-x weep out of joints/seams years after it was applied 1
