Aerodon Posted May 30, 2020 Report Posted May 30, 2020 On 5/12/2020 at 8:31 PM, 231MJ said: Thanks for the ideas. Those are some great looking panels (and the interior, PJ). Talked to the wife, we're gonna pass on the turquoise (but it was tempting). It's going to be light gray. Shop says it takes 3-4 weeks to cut and powder coat a panel. Seems like a long time - anyone have a source that works quicker (and can put the bend in the bottom of the panel)? Yes, I can cut and bend a panel for you this week, what instruments do you need to install? Dual G5 on the one attached. Aerodon, supercub180@gmail.com
Oscar Avalle Posted June 2, 2020 Report Posted June 2, 2020 On 5/11/2020 at 4:45 AM, NotarPilot said: Are you sure you don’t want “Institutional turquoise?” Soviet style ...
Andy95W Posted June 2, 2020 Report Posted June 2, 2020 5 minutes ago, Oscar Avalle said: Soviet style ... Actually, I'm pretty sure that's a DC-9. The Douglas Corporation tested different colors and found that "Robin's Egg Blue" was most visually ergonomic so they used that. 1 1
Nukemzzz Posted June 22, 2020 Report Posted June 22, 2020 On 5/12/2020 at 10:14 AM, gsxrpilot said: I'm gonna have to recut my panel as well at some point to install the second Aspen panel. I'm going to switch from the off-white to a light grey. Personally, I think that grey is a bit too dark. I like the color of Bennett's panel that you posted above or this one from Bryan's Encore. I'm looking for not too dark, but just dark enough to be able to use white type for the etched labels. How does one “etch” letters and designs on these panels? I’d like this clean look but can’t find vinyl transfers for text this small.
rbridges Posted June 22, 2020 Report Posted June 22, 2020 1 hour ago, Nukemzzz said: How does one “etch” letters and designs on these panels? I’d like this clean look but can’t find vinyl transfers for text this small. I was talking to my avionics shop. They send it out to have it etched into the panel.
carusoam Posted June 23, 2020 Report Posted June 23, 2020 Often shops use a screen print technique... Which allows them to print the details on the surface using a nice durable ink... with a thick lay down... that resists wear... Panel shops are pretty good with this type of printing, and getting instrument faces reprinted as well... So.... Find a panel building shop and see if they have screen printing in shop... For new panels there are lots of opportunities for decorating a flat sheet of aluminum including laser etching... then putting ink in the etched channels... Some techniques are tough to use when they are holding a bunch of instruments already... Best regards, -a-
Warren Posted June 29, 2020 Report Posted June 29, 2020 Some powder coat a white base, second layer with a colored powder coat and mill the letters to expose the white.
carusoam Posted June 30, 2020 Report Posted June 30, 2020 Milling would take extra skill... Maybe that is laser etched... where the colored paint absorbs the laser light and gets etched... and the white layer underneath reflects the energy... Sounds like a great technique... PP surmising only... Not a panel guy... Best regards, -a-
Warren Posted June 30, 2020 Report Posted June 30, 2020 11 hours ago, carusoam said: Milling would take extra skill... Maybe that is laser etched... where the colored paint absorbs the laser light and gets etched... and the white layer underneath reflects the energy... Sounds like a great technique... PP surmising only... Not a panel guy... Best regards, -a- Yep. That was my first thought. How can you possibly co trip the depth that accurately on a panel that will never be perfectly flat. Solution: use a cutter that uses the panel surface as a guide for depth. Works amazingly well. Here is a picture of text done this way. 2
carusoam Posted July 1, 2020 Report Posted July 1, 2020 Great details, Warren! Thanks for sharing them too. Great clarity on the tiny characters... Best regards, -a-
Airways Posted July 1, 2020 Report Posted July 1, 2020 Did anybody go for the Boeing-grey panel ? I believe the code is RAL 7011
