rbridges Posted February 24, 2020 Report Posted February 24, 2020 Is the up block pretty dependable? I'm having no issues;.I think the previous owner replaced the down block from lasar. I'm just wanting to have a part when/if an issue arises. Quote
jwarren2 Posted February 24, 2020 Report Posted February 24, 2020 Emailed for an up lock block. Quote
carusoam Posted February 24, 2020 Report Posted February 24, 2020 10 hours ago, rbridges said: Is the up block pretty dependable? I'm having no issues;.I think the previous owner replaced the down block from lasar. I'm just wanting to have a part when/if an issue arises. expect the differences in the wear come from the forces between the block and J-bar... when the gear is down... there is lots of weight and forces while moving on the ground... The problem occurs when the gear gets put NEARLY in place because a worn step interrupts the smooth completion of stowing the gear. In the down lock... the oval pattern is easy to photograph (In flight)... the wear step can be felt... If the up lock has similar issues... taking pics and feeling for worn steps is easier to do, no flying required... One thing for sure... having the J-bar release from the locks is bad... while taxiing or in cruise... PP thoughts only, not a mechanic... Best regards, -a- 1 Quote
G spot Posted February 24, 2020 Report Posted February 24, 2020 emailed. up and down lock please. Thanks David Quote
ragedracer1977 Posted February 24, 2020 Report Posted February 24, 2020 Email sent and I contributed Quote
Sabremech Posted February 25, 2020 Report Posted February 25, 2020 A quick note to the group, I’ve received many orders. I’ll put the list together and post it here for all to double check to make sure I didn’t miss someone. I’d like to submit the order by Friday to my shop as the lead time is 4-5 weeks for completed parts. The lab got back with me today and recommended 6061-T6511 (extruded) for these parts so that’s what we’ll manufacture them out of. Thank you, David 1 1 Quote
jamesm Posted February 25, 2020 Report Posted February 25, 2020 so do we E-mail you David or is there a web site.. sorry I am a little I didn't e-mail other than your mooneyspace e-mail address and wasn't sure if that was the preferred e-mail address? Quote
Sabremech Posted February 25, 2020 Report Posted February 25, 2020 5 minutes ago, jamesm said: so do we E-mail you David or is there a web site.. sorry I am a little I didn't e-mail other than your mooneyspace e-mail address and wasn't sure if that was the preferred e-mail address? Hi James, e-mail me what you’d like to order at sabremech@gmail.com. Also give me your shipping address. Thanks, David 1 Quote
jamesm Posted February 25, 2020 Report Posted February 25, 2020 side note.... How much assembly is required ? assuming that we have to disassemble and re use the existing spring and latching mechanism off our existing down lock block. that go into the new extruded down lock block. Thanks, James '67C Quote
Sabremech Posted February 25, 2020 Report Posted February 25, 2020 9 minutes ago, jamesm said: side note.... How much assembly is required ? assuming that we have to disassemble and re use the existing spring and latching mechanism off our existing down lock block. that go into the new extruded down lock block. Thanks, James '67C You will need to swap over the latching mechanism and spring. As far as removing and installing the new one, you’ll need to remove the two screws holding the gear down light and the two mounting bolt nuts, of course while the aircraft is up on jacks. It doesn’t take too long to swap out. 1 Quote
RLCarter Posted February 25, 2020 Report Posted February 25, 2020 2 hours ago, Sabremech said: It doesn’t take too long to swap out. not to play the devils advocate, but doesn't the pre-load on the gear need to be checked after the new block is installed? Quote
hammdo Posted February 25, 2020 Author Report Posted February 25, 2020 Yes, if the block is worn and new block installed, it should be done. -Don Quote
Sabremech Posted February 26, 2020 Report Posted February 26, 2020 (edited) Here's the order list so far: Alex M (FL) -- 1 downlock Richard B. (CA) -- 1 downlock 1 uplock Jon D (GA) -- 1 downlock Donald H (TX). -- 1 downlock 1 ulock Daniel K. (AL) -- 1 downlock 1 uplock Chuck M (TX).-- 1 downlock Bert C. (GA) -- 1 downlock Richard T (NH) --1 downlock 1 uplock Kieth S (?). --1 downlock 1 uplock Brice D (?) -- 1 downlock 1 uplock James M ( WA) -- 1 downlock 1 uplock Anthony H (FL) -- 1 downlock 1 uplock Joe W (DE) --1 uplock Dave B (MA) -- 1 downlock 1 uplock Greg E (TX) -- 1 downlock 1 uplock Hector P (FL) -- 1 downlock Ned G (Canada). 1 downlock 1 uplock Leo H (UT) 1 uplock Chris F (PA) 1 downlock 1 uplock Robert B (GA) 1 downlock 1 uplock John B (?) 1 uplock If your name is not on the list or you want to confirm it is you as I don't have an address for a couple of people, email me at If you haven't contributed to the drawing fund, look for Andersj in this thread and I believe you still can contribute to the gofundme for the drawings. I'm still trying to think of the best way to handle payment as I'd like for the customer to only have pay once which would include the shipping cost. Thank you, David Edited February 28, 2020 by Sabremech 4 3 Quote
Sabremech Posted February 27, 2020 Report Posted February 27, 2020 Order is going into the machine shop this afternoon. Letting the group know in case someone still wants to get in on this order? Thanks, David 1 1 Quote
cferr59 Posted February 27, 2020 Report Posted February 27, 2020 I sent you a message. I am interested in one of each. Quote
rbridges Posted February 27, 2020 Report Posted February 27, 2020 This is the message I sent to David, but I know he's busy and may not have time to play 20 questions with each of us. "I'm interested but I'm not sure if I should go with one or both? What do you recommend? Mine is for a rainy day. I believe the one on the floor (gear up lock) has been replaced, but isn't this the one that wears fastest?" What's everyone's opinion of which to purchase? Quote
Seymour Posted February 27, 2020 Report Posted February 27, 2020 Just now, rbridges said: Mine is for a rainy day. I believe the one on the floor (gear up lock) has been replaced, but isn't this the one that wears fastest I'll get booted from the CB club for saying this, but here goes: Mine is for rainy day purposes also. I see an opportunity that may not be available in the future. I missed out on the luggage compartment hinge (which I REALLY can use now) and still regret not purchasing when they were fabricated. Since both are critical (as @carusoam noted, a J-bar swinging freely through the cabin should be considered a dangerous weapon and the the upblock is crucial to prevent post-landing gear collapse) I'm buying both to sit on a shelf in my hangar. Telling the CFO to Treat 'em like my baseball cards; someday they'll be valuable....... Dave 2 Quote
romeotango Posted February 27, 2020 Report Posted February 27, 2020 Better to have it and not need it than to need it and not have it. 2 Quote
rbridges Posted February 27, 2020 Report Posted February 27, 2020 2 hours ago, Sabremech said: Order is going into the machine shop this afternoon. Letting the group know in case someone still wants to get in on this order? Thanks, David I emailed you to get a set of both. 1 Quote
Skates97 Posted February 27, 2020 Report Posted February 27, 2020 7 hours ago, Seymour said: I'll get booted from the CB club for saying this, but here goes: Mine is for rainy day purposes also. I see an opportunity that may not be available in the future. I missed out on the luggage compartment hinge (which I REALLY can use now) and still regret not purchasing when they were fabricated. Since both are critical (as @carusoam noted, a J-bar swinging freely through the cabin should be considered a dangerous weapon and the the upblock is crucial to prevent post-landing gear collapse) I'm buying both to sit on a shelf in my hangar. Telling the CFO to Treat 'em like my baseball cards; someday they'll be valuable....... Dave This thread has gone on far too long without any thread drift... I just made one out of some scrap aluminum that I had around the hangar along with a rivet and washer in between the two arms for spacing. The first go at it was a little rough but it is fully functional. I'm planning on making a better one, taking a little more time. 1 Quote
Sabremech Posted February 28, 2020 Report Posted February 28, 2020 Ok, I’ve updated the order list and it is being submitted. Will update the group as the process progresses. Thank you, David 2 3 Quote
Anders J Posted February 28, 2020 Report Posted February 28, 2020 18 hours ago, Sabremech said: Ok, I’ve updated the order list and it is being submitted. Will update the group as the process progresses. Thank you, David Crap - I missed the deadline? What I get for traveling. Anders Quote
Sabremech Posted February 28, 2020 Report Posted February 28, 2020 36 minutes ago, Anders J said: Crap - I missed the deadline? What I get for traveling. Anders I added you to the order! David 1 Quote
